kingstoneage
I called Chuck recently, and he told me for the c47, v1.00 was the latest. Something must have changed very recently, very rapidly. Either that, or Chuck and my dealer aren't in the loop on firmware updates.
I received my new C47 two weeks ago. Mine shows V1.03.
Ok, thanks for your reply!I received my new C47 two weeks ago. Mine shows V1.03.
i just changed the USB cable - no positive effect
I still don't know where the problems come from. The program, the usb cable or the C47?
I also have an album (REM - Murmur) that doesn't play correct. on some songs the bass drum does't sound correct. The original file is 192 kHz. If i play the songs at 96kHz or 384kHz everything sounds fine.....
The USB cable will either work or it wont. There is no in-between, you would be very quickly aware if there was a problem with it.
The bassdrum sounds "distorted" with a certain crackling at its original resolution of 192kHz. The bass drum is way to loud. Whe you change the resolution to 96 or 352.... everything sounds correct.
Your thoughts that something is not right with my computer settings could be the solution, but what is not right.....
My iMac is a 2011 model intel core 5 with 12 GB RAM. Not a hightec-monster but i had no problems so far with it.
Do you had any ideas what i habe to check in my settings?
Thanks a lot for your input so far!
That is not a resolution issue.....
What do you mean the bass drum doesn't sound correct? What is it supposed to sound like? Why would the wrong resolution change just the sound of the bass drum?
There is something else going on here if that is the case.
I never had much luck with Audirvana, I didn't like it at all, found it too convoluted as I may have already said earlier in the thread.
What computer are you using? All the C47 is doing is displaying what it is being sent. The C47 is not telling the computer or program what to do.
I think you may need to go and sort out the computer settings.
Not really......And you've tried using a totally different computer in order to rule that out? Did Damien from Audirvana have any suggestions?
Maybe my iMac has not the power to handle DSD256.
It is a Mid 2011 model with i5 core processor and 12GB Ram.
Just tried the HQplayer with this the DSD256 songs can't be played native!
Maybe it is a firmware problem of the C47.........it has the firmware of the C52!
