The MC-60 re-caps are done and playing but I am having trouble getting the voltages right and concerned about some redplating in the creases. I'm running old Sovtek 6550's which I do not have any experience with but I think any redplating is bad redplating.
Here are my readings. What do you think?
The three figures are for specified, amp#1 actual and amp#2 actual. Amp#2 seems to be running hotter.
V1-12AX7
pin 1 spec, measured amp#1, amp#2: 134V, 100, 101
V2-12AU7
pin 1 spec, amp#1, amp#2: 270VDC, 269, 319
pin 2 spec, amp#1, amp#2: 134, 101, 101
pin 3 spec, amp#1, amp#2: 138, 109, 111
pin 6 spec, amp#1, amp#2: 270, 269, 310
pin 7 spec, amp#1, amp#2: 110, 81, 89
pin 8 spec, amp#1, amp#2: 138, 109, 111
V3-12BH7
pin 1 spec, amp#1, amp#2: 340, 353, 369
pin 3 spec, amp#1, amp#2: 16, 16, 16
pin 6 spec, amp#1, amp#2: 340, 353, 380
pin 8 spec, amp#1, amp#2: 16, 16, 16
V4-12AX7
pin 1 spec, amp#1, amp#2: 435, 431, 469
pin 2 spec, amp#1, amp#2: -46, -46, 43
pin 3 spec, amp#1, amp#2: -46, -45, -44
pin 6 spec, amp#1, amp#2: 435, 430, 465
pin 7 spec, amp#1, amp#2: -46, -46, -44
pin 8 spec, amp#1, amp#2: -46, -46, -44
5U4, both
pin 2 spec, amp#1, amp#2: 440, 433, 475
pin 4 spec, amp#1, amp#2: 375VAC, 357, 386
pin 6 spec, amp#1, amp#2: 375VAC, 357, 386
pin 8 spec, amp#1, amp#2: 440, 433, 475
KT88/6550
pin 3 spec, amp#1, amp#2: 435, 428, 443
pin 4 spec, amp#1, amp#2: 435, 428, 443
pin 5 spec, amp#1, amp#2: -45, -46, -45.2
