MR-74 stereo light
I bought an MR-74 and it was in excellent condition except that the stereo light bulb was out. It was a 1835 bulb, 55 V. The wiring diagram indicates 40 V on the circuit. Apparently there are two versions of the stereo light-one with an 1828 bulb (37.5 V) with a 270 ohm 1 watt resister and one like mine which uses an 1835 bulb and the resistor was replaced by a jumper. The previous owner said all bulbs were working and, considering the condition and function, I am inclined to believe him. Even though it was very well packed with double boxes, I thought it might have suffered vibration during shipment. I replaced the 1835 bulb with a new 1835 bulb. The circuit worked as expected and I cycled it by tuning different stations numerous times. Although the light appeared dim to me, I have never owned an MR-74, so I assumed that was the way it is supposed to be. The light appeared to be steady without flickering and I had the tuner on for several hours. Later, I noticed that the bulb was out again. I am not sure if the bulb went out in that first session or if I had turned the tuner off and back on. A local tech friend of mine, with no experience with older McIntosh equipment, suggested that it was nothing more than a bad bulb.
Before I try another bulb, I thought I would ask the group if there is an issue with this stereo light, if anyone has any thoughts about why this bulb burned out so quickly, and if there is a solution other than just replacing the bulb again.
Thanks, Ed
