Hi Everyone , I have an issue with my Mcintosh MA-6100 . The problem is the left channel speaker woofer at mid to higher volume levels Wobbles,rumbles,pulses like a Turntable rumble but the source is a hi level AUX input. I took the output from the 6100 and pluged it into a seperate Amp input ,and the speaker works as it should.I did troubleshoot it dowm to the mc 6100's Left channel power output board. Has anyone run across this issue? I only have a multimeter no other test equipment. Any info is appreciated. Thank You, Ludman
