dbxdx5
Based on the McIntosh service bulletin, the bias for the 1700 should be 40mV across pins 12 and 4, at least that's for the version with the adjustable 50 ohm bias trimmer. It's always been assumed that the bias should also be 40mV for the version that subbed a 10 ohm fixed resistor for the trimmer, but I'd like to confirm. I ask because the amp circuits in the two versions are actually different in a few areas. Thanks.
