I don't recall the specifics, but you would go to all that work to put in a $1. used bulb?
Carl
Carl
If it helps, the part is #1835 058-037 I have not gotten into mine yet, so I can't help you with the procedure, maybe Terry can. Funny, I got mine second-hand, but it works quite well. As I mentioned, I haven't even opened it for a cleaning yet, about the only issue is a slightly dirty volume pot. The MAC 4100 I have seems a bit more finicky, it's in the shop for a problem with losing stereo mode in FM. Good luck!
When I replaced the bulb for the FM tuning dial, the blue filter was torn. On the aforementioned spare unit, the filters were like new. When I replaced one filter the two dials were two different colors, now they light up the original blue. The radio dial and the indicator lights all are solid green, FM MPX is solid red, and Tape Mon is solid yellow. I assume that those are the correct colors, since it matches the scheme of every other Mac.
I'm sure they are still available from McIntosh directly. can anyone confirm this?
Also... I read about the McBubble after I got my 1900 so at least I don't have to worry about that![]()
What is a mcbubble? And how many filters are there on the dial glass? I only see one, one the right side.
My "tape mon' lights are red, not yellow. :-(
Curious:scratch2: these "Filters" that are mentioned, are they the same as a Stage Lighting "Gell" ?
Those things can withstand a Lot of Constant heat from a much higher wattage bulb than stereo equipment.
