tomdowns
After some experimentations and investigation think I found a solution in repairing the Gain controls on The Mcintosh MC 2105. I found that the drawings showed that the Potentiometer are part 134-191 250K ohm; yet I could not find these anywhere. I pulled apart my 2105 and found the POTS are actually 134-208 and a number 1377112. I found that the POTS are made by CTS, so after a couple trial and errors I found that I could drop in the resistant ring assembly from a new CTS Part #450GT25R254A2L .. https://www.amazon.com/gp/product/B01EJY35L8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I'm not going to go into detail about marking the wires, unsoldering old pots, bend 4 tabs out, carefully remove insides of POTS, move resistance ring and back plate to old housing and assemble with old shaft. I will warn you to bent the solder terminals toward the POT before installing or they will touch the chassis.
I hope this information was useful.
Tom
Tom
