I have been listening to an MC-2125 attached to an MX-113 for a few months and recently noticed that the right side back (as you are facing the front of the unit) overheats after playing 20 minutes. It gets quite hot to the touch. The center and left side feel normal. Is this a "typical" thing for this amp? I have stacked Advents hooked-up in parallel and using the 4 ohm connection. Will this go away if I connect the Advents in series? Is this a problem that could disable the 2125 and possibly cost a lot of $$$ to repair? Your ideas and insights are most welcome. Thanks in advance.
