What did you replace the black beauties with?So much for them being good most of the time.
i know...
all of them BB's DO test 0.25 - 0.27uf, but some of 'em are probably leaky.
i just used basic mallory caps i had at work to test (and no noise or distortion whatsoever!), but planning to use either russian pio, or auricap.
i'll probably have to run the amp for at least a few days to break-in all the new parts, but while listening to it as is, one thing is for sure: sound stage, separation, and depth is unlike most other amps i've heard.
another noticeable thing is the bass reproduction. very smooth, deep and tight. those huge OPT at work :thmbsp:
some recordings sound better than others, and the funny thing is, what sounded good before (with eico hf-87 & SAE 2600) sounds so so, and what sounded so so with above amps sounds great with MC240! i guess the amp is revealing different areas of each recording.
drillher, you should try your multicaps in place of those BB's. if you decide to keep the BB and not switch 'em with multicaps, let me know. i might be interested in them.
