Made a bit more progress on the MC240 restoration this week: :thmbsp:
Went ahead and replaced all of the "bumble bee" capacitors on the main circuit board. Also, I was able to start riveting the tube sockets to the new chassis. Here are some pictures:
Changing these capacitors was way more difficult than it looks! Each lead passes through an eyelet and is then wrapped around a solder terminal and then soldered in place along with one or two resistors. To do this correctly, each of the resistor leads had to be desoldered and moved to get at the original capacitor leads. :sigh: I just don't like leaving pieces of the original leads in place when replacing these components. The new caps are much smaller physically than the originals--- thus, they fit on the board without touching or crowding each other. Having the circuit board out of the chassis surely made the cap replacement much easier. I'm sure the bottom terminals would have been very difficult to get to with the board assembled to the chassis.
The rivets are working out perfectly. Such a scary proposition at first, it now seems easy to rivet these things. I do have many more rivets to install, but it is nice to be assembling the parts onto the new chassis! :yes:
And now for a question... Do I really need to change the electrolytic can capacitors? I don't see any electrolyte leaking and there was no hum present in my initial testing of the amp.
Wes
