I recently sent my beloved McIntosh MC2105 and C30 for a long overdue overhaul at a “authorized McIntosh service depot”. When the gear came back 7 months later the first thing I noticed was the tape loop button on the C30 no longer worked. I was told by the servicer that those buttons are no longer manufactured so it can’t be fixed. they also did something to the CD input so that’s broken now too. Strike 1! After a short period of time I started to notice that the MC2105 would spike on the right meter and a loud popping noise was audible through the speaker. This problem persisted a second time so I contacted the servicer. First he said I am maybe not switching my gear on in the proper sequence and that’s causing the issue. He also wanted me to show him a picture of the interconnects between the preamp and power amp. Both these things were non-issues. He said it sounded like an issue with the power in my house. I have 220 amp service at my house and the panel was upgraded about 5 years ago. I contacted our power company and they checked from the pole to the house. Everything is fine. I called my electrician and he went through the panel to make sure our HVAC system wasn’t bleeding over into the panel. It was fine. He asked me to switch on the amp while he was checking at the panel. Sure enough it spiked and I heard him go “WOW”! He said he measured 11.5 amps at the panel when the amp spiked. Clearly it’s an issue with gear he said. I contacted the servicer and after much arguing and sending them a video of my amp doing the same thing in a different building with nothing hooked up, they finally took the amp back to repair it. Strike 2! They said the board looked like it was lose and they would repair it and send it back. 4 months later I finally get my amp back. we are now over a year. It worked great until about two days ago when. You guessed it! The right channel is spiking and popping again. I changed interconnects, speaker wire and even speakers but the issue persists. Strike 3! I have no idea what to do now. I spend thousands having this equipment rebuilt by a supposed “”McIntosh servicer”. Does anyone have any suggestions or thoughts on what might be causing this? I am definitely not sending this back a third time. I plan on contacting McIntosh to see what they think. I am not sure how they are with legacy products. Any help or suggestions would be greatly appreciated!
