I acquired some Mac gear in poor shape (see http://audiokarma.org/forums/index.php?threads/price-check-on-jbl-mcintosh-gear.698168/) I managed to save the C24 with some new transistors! However, it seems to have very weak output - unimpressive, at least - and research has led me to believe the old electrolytic caps may have gone bad.
Now I'm trying to diagnose the MC502. I'm getting no sound from the speakers whatsoever, no humming, no crackling or popping, just nothing. The transformer hums pretty good when on, which I believe is a normal issue from research I've been doing.
Thank you,
Ryan
- The lights all light up on the front, except for the Power Guard lights.
- EDIT: The bulbs ARE blown; the Limit bulbs are fine
- I believe it's a power supply issue
- I am not getting any voltage at the power supply, AC IN, pin 1 on the power supply from the transformer.
- The manual says I should be seeing 5.3V at pin 1, "AC IN", but I see 0V
- Pin 1 on the power supply leads directly back to the transformer according to the service manual.
Thank you,
Ryan
