MCintosh MC7300
Edwinyak
Anyone can teach me how to remove the knobs & glass front panel.
My MC7300 glass front panel has hazy issue need to be replace, the LED lights are dim
Hello
To take the knobs off , it is easy ! just pull them !
LED ? no LED on the front glass light
don't think that front glass can be replaced by any one . Normally this should be done by a specialist teached by the factory .
Some front glasses need to be used with old color filters coming from the dammaged glass . This is time consuming and that's why replacing a front glass is sometime "expensive"
The best example is the blue filters from the meters windows . All new front glass are delivered without any blue filters
Welcome on AK
Thks Clinic_ audio Bro, for the info
Guess i'll live with the hazy panel cos replacing the glass is very costly in singapore
Slip a rag behind it then wrap around and pull.
If you can source a new one then you can replace it. It is time consuming and delicate.
Take a lot of pictures before disassembly.
