kyledp
Hi All,
I got a good deal on a MCD7007 CD player that needs a little love. The drawer won’t open easily. I took the cover off. When I ‘help’ the drawer by gently pushing it from the back, it opens all the way. I’m able to load a disc. When I attempt to close it, again, it needs a little ‘help’ to close all the way. Once the drawer is all the way in, the disc is recognized and seems to spin fine. I plugged it into my amp and both channels seem clear, but it’s late and I can’t blast it right now. I’ll check it better for sound tomorrow.
so I’m thinking it could probably use some new belts and a good cleaning of the drawer mechanism. What used to be grease seems to be crust now. Where can I get new belts? Are there standard belts that will work? I didn’t see parts on McIntosh’s site. I could just send a message to the I suppose.
while I’ve got it open, I’d like to replace the bulbs with LEDs. The current bulbs seem quite dull. I like that bright green to match my other McIntosh gear.
are there any caps or transistors that I should consider swapping while I’m in there? Any upgrades that any of you recommend to these units?
I appreciate your insight.
