Laricc
Member
I posted a thread a while back looking for some insight on how to repair a set of McIntosh ML-1C loudspeakers. There wasn't much I could go off so I tried to contact Mr. Russel on the topic but I only got vague responses. Eventually, someone sent a picture of a pair someone else rebuilt. I ended up figuring out which drivers were using by simply eyeballing the picture. After a little bit of research, I found two pairs that looked like a match.
From here I hit another roadblock - handling the crossover. From what I know, the crossover will also have to be changed for these drivers to work properly. I lack knowledge on how exactly crossovers work so I was wondering if I could get some advice or help to fix these speakers.
Drivers:
https://www.parts-express.com/morel-mdm-55-2-1-8-soft-dome-midrange--287-020
https://www.parts-express.com/morel-mdt-39-1-1-8-compact-dome-tweeter--277-035
ML-1C service manual and specs:
http://www.roger-russell.com/ml1cservice.htm
http://www.roger-russell.com/ml1cpg.htm#ml1cspecs
Thanks.
Drivers:
Thanks.
