LED kits?
LED lighting is something that can be done by almost anyone. All that is needed for festoon bulb replacement is a good soldering iron, some brass tubing, a razor saw or similar, and some 3 mm flat-top white (not warm white) LEDs. The brass tubing was purchased at a hobby store for $4.00 for two 12" lengths and the LEDs cost $7 per hundred shipped.
In terms of figuring out how many leds are needed in series, I use the following formula.
Source voltage (must be measured) divided by 2.5 = total number of LEDS required.
In the case of the C22, the source voltage is about 26 volts. 26 / 2.5 = 10.4 or 10 LEDS. If a really bright light is desired the # of LEDS could be reduced which means each led will be at or near it's upper limit which is usually 3.0 -3.2 volts for white LEDs. In this case the number of LEDs in series would be 8.
In the case of a MR67, the source voltage is 6.3 volts. 6.3/2.5 = 2.52 or 3 leds. Three leds in series was too dim for me so I used two in series.
I thought about changing the Powerguard lights on my MC2500 amps to LEDs when I had each on the bench for cleaning and maintenance, but decided to wait until they burned out again.
