McIntosh MX-112
visim91
This Dude Abides.
McIntosh MX112
Hello everyone, I have an opportunity to pick up a MX112. The price is set at a negotiable $200. However my question is not of dollars & sense, but the condition of the unit. It has been kept in attic/basement storage for around half it's lifetime. The front glass is cracked. The stereo/mono switch on the front has come off and is missing. All else, including all lights, work fine.
I know the glass is easily, but expensively replaced via McIntosh, but where could I find a replacement for the single stereo/mono button?
I will be checking out the unit later this week and would appreciate some pointers about what else I should look out for.
Thanks!
I have always been a huge fan of the MX112 - it was my first Mc pre three years ago, and I still have one. I have owned several, and all sounded different. Enough about me...
$200 is about right. I would not go higher than this, as it probably needs $275 worth of work from Terry.
Tom Manley just got a new load of Mx112 glass (McIntoshaudio.com) and it costs $118 - you got that going for you, which is nice.
I prefer the Mx112 over the C26 for several reasons. I never had a volume pot issue (I have owned 5 of the MX112s), and I like the controls better vs. the C26 as the C26 has clicks for the bass and treble.
If the chassis is clean with no rust or pits it is worth $200. But at $200 you are $318 with a new glass, and then probably $275 worth of updates, so you are in $600. But then you will have a serious piece. Better than paying $500 for a piece that needs all the work.
I would buy it because it probably works fine and probably just needs an alignment and serious cleaning.
Get it though, you won't need another pre or tuner for a long, long time if ever.
PS. Don't worry about the button as long as it's just the button and the whole assembly. They still sell them and they are pretty cheap. I think I paid $5 for a couple extra buttons a year ago. They are the same for many of the period units.
PPS. If you're going to use it with the Mc2505, then it's a no brainer. Buy it and use it everyday.
I'm running a restored (by Terry) MX112 with an MC2100 and it sounds great! The only thing I wish it had is the variable loudness found in some of the newer preamps.
-Matt
You guys are awesome, thank you! And yes, I will use it with the ol' 2505. I'll update this thread with pics when I pick it up.
The tuner in MX112 is really nice, in my opinion. It picks up stations well and I really like the way it sounds.
-Matt
I used a MX112 / MC2505 in my office for several years. I picked up the MX112 with a MC2105, both came from Florida and the chassis were covered in rust. I repaired the bubbling on the faceplate of the MX112, cleaned it all up, serviced it, stuck it in a wooden case to conceal the rust and used it for years.
The ex took it in the divorce. I can do without her, but I sure miss my MX112 . . .
Could not agree more on these older, analog MX units. But, you should add a recap to the work list for better sonics and longer life-time. Here is a good read by the engineer who designed the C26 and early MX units.
http://www.roger-russell.com/c26pg.htm
p.s. McIntosh does not use (-) in any of its model identifiers. Is the MX112, etc.
