McIntosh XRT22 question
phil_er_up
Member
I have a pair of McIntosh XRT22 speakers and I can't get the bass under control. During loud bass passages the bass seems to be overdriven and the overall effect is too much bass in the room. I have tried isopods, mdf board, different types of room materials to dissipate the bass.
I have made progress, but one of my friends came over and said why don't I try putting speaker spikes into the bass cabinets and then the whole house will move with the bass.
I see there are silver round feet on the bottom of the xrt22 and wasn't sure if those are screwed into the base cabinet of not?
Any suggestions on how to go about this? The bass cabinets are 90 pds do I only need 4 speakers spikes and any suggestions on what kind or how to do this without damaging the base cabinets?
Thanks
Patrick
The spikes should help. I find that spikes on the bass cabinets give the bass more focus and slightly reduces bass bloat. I would think those silver round feet are screwed in and you could try to get spikes with the same threads. On my XRT30 bass cabinets I use 3 free standing spikes, 2 at the rear and 1 in the front. It is a little work getting the bass cabinets in the right position and on the spikes, but no big deal.
There are many other ways to improve the bass.
Get the bass cabinets away from the walls, how far are your bass cabinets from the front and side walls?
What amps are you using and are you bi-amping? If you have McIntosh amps with autoformers you could put the bass cabinets on a lower ohm output tap, this will reduce the bass by 3db.
You could always add an equalizer, I'm using the MQ109B with great results.
I have not used them but I hear ASC tube traps do a good job as bass room treatments.
Victor
Bass cabinets are 3 feet from back wall and 2.5-3.0 feet from side wall.
No bi-amping , Mcintosh MA 6900 - 200 Watts PC with autoformers
What kind of free standing spikes do you use?
Have an old Numak 10 band EQ that I could use.
Room size: 14X20 Ceilings 7'
Sound system:
Mcintosh MA 6900
Mcintosh XRT22
Mcintosh MR74
Mcintosh DVD/CD 861
Replaced all power cords and use Audioquest cables (have others too)
RGPC 400 with RG HTW
RG Pole Pig with RG HTW
Dedicated 20 amp circuit
All AC outlets upgraded to Hospital grade.
I have moved the Base cabinets 5 feet from the back wall and the bass actually increased. Started moving them back toward the wall slowly and kept experimenting. As I moved the cabinets back toward the wall from the five feet the bass started decreasing. As I moved the cabinet to close to the wall it started to increase again. So my current set up is where I found the bass to sound the best, but would still like to tighten up the bass. I have used rugs and curtains and foam and several other types of treatments and they seem to help. My next thought was spikes and that is what lead me to write this post.
Could always get more power but a pair of 501 is not in the budget and I think those amps would help tighten up the bass.
The spikes I'm using came with some Avalon Eclipse speakers I used to have, see pic below. They are a little over an inch high and about 1 1/2 inch diameter. I use 3 under each bass cabinet, it is very stable with 3. Just make sure the spikes you get will pierce the carpet.
It sounds like you have the speakers a good distance from the walls. My bass cabinets are about 3 feet from the back of the cabinet to the front wall and about a foot from the side wall.
It is also possible that the loud bass passages are pulling your amp down causing mid and high frequency collapse which causes the bass to be over exaggerated. MC501s would be a simple but expensive answer.
I found bi-amping greatly helped my XRT30s. If I remember correctly the XRT22 have the crossover for the tweeter column in the bass cabinet which makes it very difficult to bi-amp these speakers. So this is not much help for you.
I would try the spikes first, you should be able to find some online. You could give the EQ a try but some older EQs add noise and hurt the sound but since you already have it might as well give it a try. ASC tube traps may be the answer but they are expensive.
Victor
2 more things that may help. It is usually a good idea to keep the bass cabinets a different distance from the front and side walls and to toe in the bass cabinets (never have them firing parallel to the walls). This should reduce standing waves.
Victor
You should definately experiment with bass cabs positioning, I would also try moving them closer as well as further away from the walls, you never know where and what room modes are excited and usually there will be a few spots that are more benign than others. What are the dimensions of your room where the 2 bass cabs reside?
plenty of talk about speaker position but nothing mentioned about sitting position- is this flexible? have you experimented with this also? Even 1 foot makes a huge difference. And I hate to say it, but at my brothers he had the same problem, and on some songs the only solution was to turn the volume down... he has the same speakers. How are you liking the XRT 22's?
Yes I can move the sitting position quite a bit. The moving of the chair does have an effect on the sound but the room has too much bass on certain recordings.
I have experimented with moving the bass cabinets forward and back in relation to the tweeters too. So there are at least 4 components here just for speakers postion, the closeness to the back and side walls and the evenness of the bass cabinet with the tweeter column.
Do most people line the tweeter columns even with the bass cabinets?
What are the general ideas of how to set up line array speakers in relation of the bass cabinet to the tweeter column?
The person I bought the speakers from had the tweeters on the wall and the bass cabinets about 1.5 feet away from the wall. If you looked at a side view the bass cabinets were way in front of the tweeter columns. His approach sounded fine but he had very high ceiling and 3 rooms were connected together. When I tried his approach at home there was more bass than there is now.
Some other ideas I have toyed with:
Do the xrt22 accurately reproduce low bass notes?
Is this a speaker design issue too?
Never really heard anyone talk about the Mcintosh line array speaker seriea and how they handle bass in general.
Thanks for all the replies. Still mulling some of your answers over.
I had a pair of XRT22s up until about a year ago. (I upgraded to XRT28s.) I always found that the XRT22s were a bit bass heavy as well. With two older 12" woofers, I found that it really made my room reverberate. That hot frequency was about 80 hz and I suspected it was a result of my walls. (The dry wall vibrating.) I tried many things, and found the best and easiest way of dealing with it was equalization. (I didn't have the space, so they had to be against the wall... which Roger Russell, the designer, recommends.) I own a 1/3 octave analyzer and found that I needed to attentuate 80 and 400 hz. Once I eq'ed those freq, I measured a pretty flat response (+/- 3 db) from 20 hz to 20khz. (My XRT28s only needed eq'ing at 400 hz... probably because of the smaller LD/HD woofers.)
Hmmm,i must be missing something here,you said your running the xrt 22's with a MA6900 intergrated amplifier,that intergrated has a built in 5 band equlizer,a simple twist of the controls should easily take care of any bass problems your having.
Are you using any tone control on the amp or are the tone controls set on bypass?.
If the tone controls dont help & speaker positioning dont help i'd say that you have some serious issues with room accoustics that need to be addressed.
FWIW , XRT 22's were not meant to be used with spikes,they came with removable risers,i find that i get a more focused & precise bass response when using the risers,ive tried them a few times without the risers & the bass sounds floppy & bloated.
The xrt 22's have an excellent bass response & handle bass great,keep in mind though that they are a speaker thats designed to go deep in the bass response,if your not used to a full range speaker that has a full bass response any full range speaker with deep bass may seem bass heavy to you.
As for speaker setup the bass cabinets should be on the outside & the tweeter columns should be on the inside of the bass cabs,the columns should not be any further than 3ft apart from the bass cabs,both the bass cab & the column should be even at the sides & no closer than 8 inches away from the bass cabinet.
The main issues that any Mcintosh dual cabinet line array will have are mainly placement issues,the XRT 30's will be effected by the same placement issues as your XRT 22's .
Copied from Roger Russell's Mcintosh history page below.
McIntosh XRT22 Speaker System
A History
The bass cabinet contained two 12" woofers and one 8" mid-range. As in the XR19 and later versions of the XRT20, The lower woofer covered the range from 20Hz to 150Hz. The upper woofer went from 20Hz to 250Hz. The use of two different woofer crossovers reduced interference between the woofers in the upper bass where the distance between them was significant compared to 1/2 wavelength of the sound being radiated.
The woofers were vibration isolated from the cabinet using cast aluminum mounting rings and foam tape. Our research, using an accelerometer attached to the cabinet in many areas, showed that additional internal bracing did not effectively reduce cabinet vibration. It only shifted the areas of maximum vibration to other areas that were not braced. Our method of woofer vibration isolation virtually eliminated all cabinet vibration and any consequent secondary radiation from the cabinet surfaces.
The 8" mid-range was contained in a sealed enclosure and covered the range from 250Hz to 1500Hz. The bass cabinet grille was changed to cover only the front of the cabinet. Gordon Gow found that by extending the grille to the top of the bass cabinet, the appearance was much more acceptable.
The tweeter column was changed to be one continuous piece of wood like my original XRT20 prototype. Early versions of the XRT22 columns were made of solid oak or solid walnut. Later versions were veneered high-density particleboard and the grilles had a small radius in the corners. Twenty-three 1" soft dome tweeters were used. The tweeters were wired in series parallel with a 16 ohm series resistor in one group.
The column width was the same as the XRT20. It controled the tweeter rolloff at 1.5kHz. I confirmed by measurement that making the column narrower did not support the lowest tweeter frequencies and that making it wider gave it too much low end. Tapering the width of the column from bottom to top was ruled out. That caused a change in response at different heights that could be easily heard and measured out in the listening area.
As I described in my original design and patent, the tweeter column offered several advantages. Each tweeter could easily handle 10 watts of steady sine wave power at 0.3% distortion, making a program power handling of 250 watts very conservative. The high power handling made a low crossover frequency possible as well..
Over the years, we found the soft woven textile dome tweeters to be superior to the metal and plastic dome tweeters. The Philips soft dome tweeter was custom made for McIntosh. I specified a special undercoating that was not their standard production. This damped out a resonance that would otherwise be significant. The plates were rectangular to allow close vertical spacing. The column was only 1-5/8" thick. It could be hung on a wall with a single heavy-duty picture hook, or mounted on an optional CS22 stand. The vertical response was greatly reduced above and below the column extremes. As a result, floor and ceiling reflections were drastically reduced and more accurate sound reproduction was achieved.
This was the original XRT22 crossover wiring sample that I made for production. It was also used as the standard crossover for the test procedures. Various pieces of tape and markings were added by production people to easily identify parts and wire lengths. This board survived many years of handling.
Typically, crossovers such as Butterworth, Chebychev and Linkwitz-Riley were nice as a starting point. However, the finished crossover didn’t necessarily resemble any of these. As in other McIntosh crossover designs, the components were adjusted to produce the correct acoustic phase and response in the crossover region. Passband adjustments were also made if necessary.
The credenza shape of the bass cabinet was acceptable in the home. In addition to presenting an attractive shape, the two angled sides reduced reflections from the tweeter column when it was placed near the bass cabinet. They also provided some non-parallel interior cabinet surfaces to reduce standing waves. The edges of the tweeter column were angled to match the bass cabinet.
By using the tweeter columns on the insides of an XRT22 stereo pair, the arrival time between the bass unit and the tweeter column was very satisfactory in the normal listening area. Also, a spacing of 8" was recommended between the edge of the tweeter column and edge of the bass cabinet. If the column was closer than 8", there could be reflections from the shallow sides of the bass cabinet. If the distance between the center of the bass cabinet and the center of the tweeter column was greater than 1 meter, the system could be perceived as two separate sound sources.
Here is an appreciative letter from a customer (TH) sent to me by Bill Tandberg
at Hi-Fi Haven in Whittier, CA.
TASTING THE McINTOSH XRT-22
April 29, 1988
Edited for space.
THE STARTING POINT
I had wearied of what seemed to me a "lifeless" sound from the so called "High Fidelity" Long Playing records and had all but given up on tinkering with recorded music until the compact disk surfaced and I heard the full and accurate sound that was possible from a recorded source. With this exciting new development in sound I quickly decided to upgrade from my older McIntosh equipment to the very latest McIntosh apparatus. The McIntosh XR-19 speakers appeared an ideal choice for me because they were powerful enough to fill my large listening room, were beautifully housed in a handsome walnut cabinet, and most importantly, produced a dazzling spectrum of sound that included a profound bass, as well as the clean, sparkling treble range so often lost in a fog of confusion with many speakers. So, I have been enjoying the beautifully sweet and oft times thunderous sounds of the XR-19 speakers for several years. I was inspired by the sound of the McIntosh XR-19 and its vertical row of in‑line radiators (tweeters, mid‑range & woofers) arranged around a single vertical axis, and additionally the low‑frequency crossover for the two 12 inch woofers. These seemed to be important concepts in producing a clean, in phase, musical picture, and the larger XRT-20 speakers lacked these seemingly important attributes. My thought was that having different portions of the radiating surface offset from a vertical axis certainly should produce out-of-phase relationships between the various speaker components when compared to the original recorded signal. For me, most listening is done within 15 feet of the speakers, so I assumed any horizontal displacement of speaker elements along the vertical center axis would be detectable as a loss of clarity, dimensional imaging, or some other undesirable trait.
I have never listened to the once fabled XRT-20 speakers which were the top of the line when I purchased the XR-19's. I didn't imagine the XRT-20 speakers could be more articulate than the XR-19's, and I did not feel I needed the extra power the XRT-20's could dissipate. I loved the sound and appearance of the XR-19's. All the XRT-20 seemed to offer was 12 more tweeters - tweeters that were offset/displaced from the central axis of the mid‑range and bass speakers, and, in addition, no low frequency crossover was listed in the specifications as with the XR- 19's. Added with these concerns was the significantly greater cost and unavailability of local XRT-20's for listening. Had I taken the time to search out and listen to the granddaddy of the McIntosh speakers then, I might have had a different approach to tweeter columns now. As it was, I fell into trying the XRT-22 while still not liking or wanting a system with columns. I was still resisting the appearance and idea of columns even after the XRT-22's had been set up. Then I listened to them - that astonishing impact of sonic beauty that dazzled the senses. I was still resistant to changing my entrenched ideas, but after a short period of listening my unyielding notions began to dissolve under the stunning ecstasy of acoustic beauty that now engulfed me.
SPEAKER SPECIFICATIONS
Electrically they are equally impressive with a 250 watt, 20 to 20,000 hertz, continuous sine wave rating. That means you can plug them into a clean power source operating in the 20 to 20,000 cycles per second range while continuously putting out 250 watts of electrical power, and leave the speakers buzzing away forever without them melting or bursting into flames.
The input impedance is 8 ohms (nominal). Crossover Frequencies are 100, 250, and 1500 hertz. The 100 hertz crossover affects the output of the two woofers, and is partially responsible for the wonderful detail that is evident in all the bass frequencies. Electrical connections for input and the separate column are located on the back side in a small recessed area near the bottom of the cabinet. A five amp fuse for overload protection is also located in this recess. The main speaker cabinet contains one 8 inch mid‑range, and two 12 inch woofers. Cabinet dimensions are roughly 26 inches wide by 40 1/2 inches high by 13 inches deep. According to Roger Russell at McIntosh, whom I spoke with briefly, the XRT-22's utilize a newly designed bass speaker which he said is much more distortion free and uniform throughout its range than bass speakers used in earlier designs.
The tweeter columns are fairly heavy and can either be hung on the wall, or mounted on optional stands. Construction is anything but flimsy. The solid wood frame surrounds what appears to be a rigid steel trough which, in turn, holds the twenty three 1 inch tweeters. Column measurements are approximately 10 1/2 inches wide by 79 1/2 inches high by 15/8 inches deep ‑ not including optional stands. A steel ring near the top of the column provides a method of hanging the column on a wall. Caution is in order here as the column is heavy so whatever supporting hook is placed in a wall must be affixed into something solidly constructed. Column stands are optionally available as a set (2 each) and weigh about 37 pounds for the pair. They are nicely constructed and seem to provide adequate support for the top heavy columns.
With the incredible dynamic range available on today's Compact Disks these speakers should be used with some discretion. Many disks contain passages with very low volume levels which can unexpectedly build quickly to booming crescendos. I doubt you'd damage the XRT-22's, they'll put out most anything you could pump into them, but the McIntosh Service Contract that comes as part of the purchase price will not cover any reconstruction costs to your home or loved ones.
ONE FATEFUL DAY
One late Saturday afternoon, almost by accident, I stopped by to visit Bill Tandberg of Hi Fi Haven. Several of us seasoned "Hi Fi Haven-ers" were sitting around chatting about unimportant stuff and somehow got into debating the sound of the new McIntosh XRT-18 speakers. We wondered how the super-duper XRT-22 speakers would sound, and theorized what they could do. I was not an adherent of tweeter columns, and was concerned about the vertical axial displacement of various speaker components and its effect on the sound reproducing system. As the conversation progressed, Bill Tandberg (Hi Fi Haven) mentioned he might get a pair of XRT-22's for demonstration in the store. Before long I had somehow agreed to take them home and give them a listening and comparison test before they were installed in the store for demonstration purposes. Bill understood that I often can hear detail within sounds that are helpful for evaluation, and that I would not race off to Brazil once I had the speakers home. I agreed to test the speakers against the XR-19's and write up something that Bill could show other customers as a lay persons evaluation, so the following Monday they, the XRT-22's, were ordered.
THE DAWN OF TRUTH
The XRT-22 speakers were set up, moving aside the veteran XR-19's, with the columns mounted on their matching furniture floor stands. I intended to work with the XRT-22 speakers and learn how to use and listen to them for a couple of days before I tested them against the XR-19's. This listening test against the XR-19's never happened! Even before the XRT-22's were equalized for my room it was instantly obvious that they were spectacularly different than the XR-19's. Any comparison test already was of no interest to me. My initial impression was that the treble and transient high frequency data is so accurately delivered, and with sufficient power, a superb feeling of surrounding presence is manifest that is not matched by speakers less capable of delivering massive amounts of highly accurate tweeter energy.
Next, the speakers were equalized using a Soundcraftsmen Analyzer so that the entire frequency spectrum from 20 to 20,000 hertz was being delivered at an apparently equal sound level. For the first time, with any speaker I had personally equalized, I was able to adjust the 15,000 hertz octave at a power level high enough to achieve an equal sound pressure level compared to lower octave bands. Always before, I set the 15,000 hertz octave adjustment all the way up for maximum output - and it was never enough. Now, it wasn't at maximum and there was additional power available if I needed it! Apparently, the "circular" arrangement of the 12 tweeters in the XR-19 speakers could not deliver enough power at a specific point as each tweeter unit was pointed in a slightly different direction. The XRT-22 differs in that you have 23 tweeters looking almost directly at you!
The radiation pattern of the XRT-22 is nothing short of amazing. You can walk around to the side of the high-frequency columns and the sound is still there! You have to be almost directly at the side of the column before the sound begins to quickly attenuate. However, as an experiment I hung the columns directly over, and in line with the center of the bass speaker cabinet, to see what differences I could notice. Now, the equalization curves for the upper bands were noticeably different, and I was not able to obtain enough audible energy in the 15,000 hertz octave to equalize this band. Furthermore, the listening test produced unexpected results. For this room, the effect was one of painful confusion in all upper octaves; and comparatively the bass seemed overly intense. Also, if my position, or listening level, dropped much below the bottom line of the columns, the entire treble section quickly, and dramatically, diminished in volume. Its almost like the radiation pattern is a semi‑circle of sound when looking down from the top of the column, but that semi‑circle is somewhat flat at the bottom. Possibly all tweeters emit a "flat semi‑circle" shaped pattern. With the columns mounted over the bass cabinets, the tweeter emitted confusion I heard would probably be apparent to even a deaf person. A friend with me at the time also noticed the same effect. I'd liken this acoustic outcome to looking up through 23 layers of sound and experiencing hearing all the layers at the same time with each being out of phase with all the others.
After going to all the trouble to hang the heavy columns safely at high altitude, I quickly re-hung them at a height about the same as if the columns were mounted on their stands. The speakers were then re-equalized to compensate for the lowered column positions. By hanging the columns on the wall I can get them a few inches closer to the bass speakers then if they are mounted on the column stands. A secret of column placement appears to lie in having the columns positioned at a height so that the average level of the listener’s ear (standing vs sitting) is near the mid point on the height of the tweeter columns. This is what you get when you use the column stands. I don't know why this seems to work, but I notice that when my listening level moves to the lower (and probably upper) edge of the columns, as when lying on the floor, I am at an "edge" at which the volume and impact of the high frequency columns begins to decline. I have not bothered to climb a ladder to see if the same attenuation occurs at the top end of the columns.
When the tweeter columns are positioned as described above the musical results are so rich that I have little inclination to continue poking holes in my wall to test other speaker positions, and I have no further interest in comparing the XRT-22's to the XR-19's. Not that the XR-19's are poor speakers by any means, rather, the XRT-22's are so very distinct to my ears a comparison seems a futile effort when I could be enjoying this new musical extravaganza instead. I can only speculate on how McIntosh engineers were able to so perfectly harmonize 23 distinct points of high frequency radiation into the feeling of a "single point source" of sound. It's as though a secret process has been discovered to coordinate all the infinite acoustic complexities into one complementary whole. The masterful blending is so articulately complete that to describe it in cold type is to disgrace the elegance of the XRT-22.
THE TASTE OF MUSIC!
I have no way of really describing the effect and sound of the McIntosh XRT-22 uniform field speakers. To my ears, the balance of sound is spectacular. I can move around the room and have no feeling of having to adjust the volume to compensate for my position. The presence of the reproduced music is astonishing. Even the cannon shot from Telarc Compact Disks was handled well, and music was clearly evident through the duration of the cannon blast. According to the meters on the amplifiers, the power output during some of the cannon shots equaled, or slightly exceeded, 800 watts per speaker. The speakers didn't seem particularly disturbed by these explosive blasts, but it is frightening to remove the speaker grills and watch the bass speaker cones move with such extreme excursions. The moving parts of the bass speakers become a blur of motion. Even though the XRT-22's seem to take it in stride, I hate to subject the speakers to such intense mechanical punishment for fear that flaming debris will be violently ejected out into the room. As you may well imagine, two speakers pounding out 800 watts each of cannon in one room (add another 200 ‑ 300 watts of reverb from the rear) dims the lights and slaps the ears with a concussive wave. It's the first time I've ever had my ears feel a tinge of pain from something "musical" out of a bass speaker. Talk about a cannon blast impact! What a jolting surprise these babies could have on your unsuspecting friends!
I thought the XR‑19's were incredible, and they are, but the feeling of a third dimensional, or spatial, placement of the orchestra, or whatever you're listening to, is quite noticeably improved with the XRT-22's. The sound of the music is exceptionally "solid." It's just "there," and it is normal for me to have the feeling of the artist(s) being present in‑the room with me. Sometimes I even catch myself hearing a passage and spontaneously looking to see if some phantom musician is actually sitting nearby.
All my misplaced concerns regarding the displacement of the tweeter column from the center axis of the other radiators have been assuaged. If I stand between the two sets of speakers I can indeed hear a slight timing difference between the column and bass speaker cabinet. This difference is more evident for any sharp change in intensity such as a drum strike. Interestingly, this difference does not exhibit itself as distortion in the sense of something painful, but rather a displacement resembling an echo. To be sure, the spatial imaging is altered when standing between the speakers, but by just stepping back a few steps the sound is beautifully blended and transparency restored with any axial misalignment somehow magically unimportant. At a distance of approximately 10 feet the blending of the bass and column radiators is near perfection. At distances of 15 feet or more the blending is perfection. However, these may not be the speakers for you if you plan to put them in a shoebox sized room; and if you plan to hang the hefty 23 tweeter columns on the wall be sure to use hooks that won't pull out under a heavy load. A 100 pound rated picture hook nailed into one-half inch wallboard or plaster is doubtlessly asking for disaster. If hanging weighty columns on a wall doesn't appeal to you use the column stands available from McIntosh instead. They work well but require more floor space then I want to devote. The column stands are well made with adjustable feet that extend from the back side providing enough support to keep the mounted columns from easily toppling over backwards. The column stands come two to a box in a kind of "screw it together yourself' kit. They are easy to assemble, and the scant instructions are adequate.
The quality of the recording is paramount if you really want to hear what these speakers can do. Recordings poorly made will sound correspondingly poor. Naturally, a recording with distortion will not sound pure and clean, but the XRT-22's will reproduce the recorded distortion flawlessly. How ironic that a cheap inarticulate speaker may actually make a terrible recording sound better than it truly is, but only because the pitiful speaker cannot reproduce the incoming signal. It is important to note that while the third dimensional feeling from these speakers is phenomenal, it can be easily lost if the recording was improperly miked or over mixed, and many disks I've tried are "flat" due to audio engineering ineptness. Some disks are naturally "flat" due to the type of recorded material, synthesizers being a case in point. Blaming the speaker for these recording shortcomings is altogether inappropriate. Most compact disks I've played are superbly demonstrated by these speakers. Even some disks that contained marginal overloading or distortion of the recording media, such as massed orchestra & chorus, often show remarkable improvements in clarity over the XR-19's.
It was quite a lesson for me to realize just how much of the musical score comes out of the column assemblies. There is much more going on in the tweeters than often meets the ear, and until I was facing a speaker array that could deliver the real stuff I didn't notice the true importance of "tweeter deliverance." Even for deeply bass musical tones a large amount of data in the form of harmonics and transient data comes out of the tweeters. I hadn't even dreamed of how much I was not hearing without having sufficient tweeter driving force. I now feel that one, or even a few tweeters, in a speaker assembly most likely cannot deliver what is really needed to give you the balanced realism that is now possible with these powerful XRT-22 transducers.
Often, the results of careful listening with the XRT-22's is whimsical. Frequently I clearly hear the musicians moving about or dropping some tiny object. On one notable disk the sound of a door slamming shut is clearly audible in the background while the orchestra blithely plays on. Yesterday, I played a disk of Beethoven's 4th Symphony. Although I'm sure it was unintentional, the orchestra sounded like it had just graduated from High School. Much of the score was played with a semi professional character, while some of the more discordant sections sounded just like that High School Concert where your kid was part of the orchestra. Remember? You applauded anyway! The sound was great! It sounded so real I couldn't help but earnestly enjoy listening and "pinpointing" the sour musicians in this comic performance. I could easily locate their unambiguous position. In the old days, before these powerfully realistic speakers, a "sour" recording was usually just a wearisome experience. Now I could find the errant players, and have fun too! This ability to hear many humorous and unplanned background events may not strike you as a reason to invest in speakers such as the XRT-22, but, in fact, this almost comical attribute is a major reason to demand such grand speakers.
If your current sound system cannot pass these often hidden parts of the total recording on to you with ease, you should consider what else your old fashioned system is hiding from you. Truthfully, do you really think you can hear what your precious recordings can offer when your system excludes certain types and ranges of sound? Is a poor imitation as good as a bona fide gem? Most of us would consider attending an authentic performance a prize; so why then do we often place more value on a recorded reproduction that lacks many of the qualities we genuinely treasure? Why is it we sometimes place the greatest value on the least accurate reproduction when it resembles our "picture" of what we wish to think is true? We then claim our system is the best, when the truth is it couldn't endure the comparison test of an actual live performance. I have have been guilty of this as well as the next person. One thing I have gradually learned through experience by carefully equalizing and maintaining a "lifelike" high fidelity system is that my former acceptance of the standing resonances and imbalances in both the room and electronic system had gradually perverted my sense of "good" hi‑fi music into an "exaggerated and booming" bass with rolled off high and transient frequencies. Many hi‑fi enthusiasts even today say they prefer the booming "tunnel like" bass and the "less-harsh" sounding treble as a sign of excellent high fidelity reproduction. This is particularly prevalent for those long accustomed to only a simple bass or treble adjustment and/or the vintage LP's, once the vanguard of superb quality. I also used this same criteria as a ruler for selecting a worthwhile system. When I first accurately equalized the entire sound spectrum of my system for a balanced "lifelike" sound I was disappointed in that it no longer sounded like the adulterated result of hi‑fi systems I was so used to hearing and thinking were the "right" choice. Almost immediately, however, I adjusted to this "different" sound and have become exceedingly appreciative of the "Lifelike" virtues that had been entirely lacking before. Once I had advanced into this new world of understanding and pleasure, my goal has been to hear all the minute detail, dynamic range, and lifelike spirit that is possible, and never again to hide from the subtle and realistic details of true life.
Powerful passages are particularly different than earlier speakers I've heard. I notice immediately the lack of confusion when the speakers are really belting it out! There is exceptional cleanness in all tones from bass to extreme treble ‑ no matter what the speakers are doing. Massed orchestra with a large chorus is a wonderful listening experience. Even if the original recording suffers slightly, the distinction of separate tonal voices is remarkable. For each Compact Disk I've played, whenever the musical intensity increases to a mighty roar the transparent clarity of minute and intricately exquisite tones remain flawlessly intact and distinctly clear. Still more impressive is the way a strong bass presence can suddenly rush out and fill the room with deep vibrating tones of exciting intensity. Its spine tingling when these sonic eruptions are physically felt too, and as the room shakes in harmony the thunderous bass remains just as immaculately clear as ever.
XRT22 Specifications
Response: 20Hz to 20,000Hz
Power rating: 250 watts continuous, (500 watt occasional peak)
Output sensitivity: 87dB/watt/meter re: 8 ohms
Impedance: 8 ohms
Woofers: two 12" McIntosh
Mid-range: one 8" McIntosh
Tweeters: twenty three 1" custom soft domes
Crossover frequencies: 150Hz, 250Hz and 1500Hz
Overload protection: main fuse
Finish: walnut or oak
Dimensions: Bass section: 40-3/4" high, 25-3/4" wide and 12-3/4" deep
Dimensions: Tweeter column: 79-1/2" high, 10-1/2" wide and 1-5/8" deep
Weight: Bass cabinet 95 lb.
Weight: Tweeter column 61 lb.
Sold from 1986 to 1993
Last retail price: $9100.00 /pair
CS22 Stand
Finish: Walnut or oak
Shipping weight: 37 lb./pair
Last retail price: $600.00/pair
Created by Roger Russell
All contents are copyright 1996-2005
by Roger Russell All rights reserved
My reference to being bass heavy was not only from listening to them, but by measuring them with a 1/3 octave analyzer. When you unleash the volume of sound that 2 12" woofers can unleash, it's going to reverberate anything sensitive to reverberation. In most rooms, that will be the walls. The XRT22 was also a more forward, and had more distortion in the low-end (giving them a "wooly" bass sound) than the current LD/HP speakers that McIntosh puts into their current speakers. I found this to make the impact of that hot spot of the low end more evident. That all said, a simple equalizer adjustments took care of it all.
I cant figure out why he cant correct the bass with the 5 band eq that his intergrated is equiped with :scratch2:.
I can correct some of the bass with the 5 band EQ. I listen to a lot of live music and each one sounds different. So I can't really just leave the EQ in one place.
I brought up the Numark 2600 EQ and it made a big difference and put it in the system. Now I can pinpoint the exact frequency and cut it back. Still thou these speakers put out a lot of bass. So still thinking of spiking them.
Thanks for all the responses.
-p
If the speaker is eq'ed properly, you shouldn't need to adjust for each recording. I eq'ed mine to be flat and don't have any tone controls (I have a balanced preamp). I found that the bass varied between recordings.... but never enough to want to adjust for it.
