starcopy
Hi, MCS fans. Just found a decent-condition MCS 3233. I see and hear the potential in this well-made receiver. Not sure if it will need components replaced -- that comes later. Right now I’m working through the 3233 functions, switches, dials, connectors, jacks, etc. to see what I’ve got here. I’ve done considerable research on AK, cleaned controls, repaired the cabinet, ordered new LEDS/sockets, etc. But I'm stalled on a few issues. And 3233 documentation is hard to find. Any advice would be greatly appreciated.
1. Has a stepped (click) volume control, but no sound in right channel at the lowest volume (first click up). Otherwise fine. Probably needs a better DeOXIT cleaning? Or I can live with it. Minor issue.
2. 3233 Phono 2 function = very, very faint music -- even at highest levels. Conversely, the Phono 1 setting delivers EXCELLENT sound with my MM cart. Are both phono inputs identical? Or is it possible that one of the phono inputs is/was meant for a different type of cart? Maybe a ceramic cartridge? (The transition from ceramic carts to magnetic carts did occur during the time this unit was built.) I have cleaned this switch with D5. Twice maybe.
3. Felt a slight electrical current when touching the 3233 metal faceplate while standing in my garage in my socks. But no electrical current was felt when I reversed the power cord and made sure that the “ribbed” side of the power cord was in line with the larger slot in the electrical outlet. Do I replace the entire power cord with one that has a wide blade -- making sure that the ribbed wire is always in line with the wide blade and properly grounded? Or just replace the plug (but that would look clunky.)
4. Also RE above: The slight electrical shock was only felt when I touched the faceplate, and not the rear painted panel. Did the paint act as insulator?
5. The “signal strength” meter does not move – buried at the “O” (rest) position. (But, the tuning meter just started working this morning. No kidding. Really. Yeah!)
6. Hear a loud, real-time thump in speakers when powered up. My temporary workaround to protect speakers is to turn the unit on “in headphone mode.” Should I be looking for a dirty, faulty relay? I had the unit opened up for an initial cleaning, but did not think to look for a relay at that time.
7. Am in the process of replacing the four dial sockets/bulbs with the help of an AK member but no affiliation. It appears that each of the original bulbs were "surrounded” by a clear, blue plastic “bowl.” Now very faded, these bluish “bowls” look like they were meant to produce a blue dial light. Can anyone confirm that the 3233 dial lighting was blue? (Please, no “Captain Obvious” jokes here, okay LOL?)
Many thanks. BTW, sorry for such a long post with so many questions. It just seemed like a very efficient way to tackle a number of issues at one time with this one machine.
