I assume you have these numbers on the back of your receiver 683-3233-10Love that album! I have it too.
It sounds great on my MCS 3235I would use what the stereo calls for. If the fuse is sized for a larger amperage, then the protection is inadequate. If it is sized smaller, then it will blow before the full potential power of the stereo is reached. What sizes are in it?The back of the 3233 calls for 3 identical fuses to be used. All should be 3AMP/3AG fuses -- it's stencilled right on the back panel.
My two speaker fuses are the same, but they are not 3AMP/3AG fuses. The filament is straight, has a slight zigzag, and is identical in both.
The third fuse is not the same as the two speaker fuses. And it, too, is not a 3AMP/3AG fuse. And the filament has a very aggressive, noticeable zigzag shape.
Does all of this matter? One another forum it was noted that the 3233 is very picky about its fuses. And mentioned that the sound passes through these fuses - or similar language.
In another thread, MCS Guy notes that the fuses are a weak part of this unit (or similar language, my language not his). So, anything we do to improve the situation? It appears that the previous owner of my 3233 put in new/different fuses and everything works fine -- no blown fuses, but then again I've never pushed the 3233. Any other solutions to this issue? Do I need to upgrade my fuse game? Maybe I should just leave well enough alone.
The one fuse is a 3A 250V 312. The second and third fuses (both speaker fuses) are identical BUSS AGC4 250V with "UL" and "SA" logos on them. Does that help? I'm guessing -- and it's purely a guess - that a previous owner made some deliberate fuse changes or "upgrades" or whatever. Just not sure why?I would use what the stereo calls for. If the fuse is sized for a larger amperage, then the protection is inadequate. If it is sized smaller, then it will blow before the full potential power of the stereo is reached. What sizes are in it?
That is a 4 Amp semi-fast-blo and are supposed to be 3 Amp. You do want fast blow unless it calls for a different type. I would put in what it calls for which is 3A. The "zig-zag" won't matter and is actually not quite as "fast" blow as a straight element one. If you don't really crank it, you'll be fine with the 4A speaker fuses. But definitely put the main power fuse what it is supposed to be. If something blows internally, you WANT the main power fuse to blow as it should to minimize any damage.The one fuse is a 3A 250V 312. The second and third fuses (both speaker fuses) are identical BUSS AGC4 250V with "UL" and "SA" logos on them. Does that help? I'm guessing -- and it's purely a guess - that a previous owner made some deliberate fuse changes or "upgrades" or whatever. Just not sure why?
It's bad practice to sit anything on top of a receiver, and especially a turntable. Besides the instability and heat, the phono inputs are very sensitive and a TT is an antenna. It was probably picking up RF noise from the receiver and feeding it back into the inputs.Thanks for posting -- and for the good advice @Skywatcher and @Racingh11. Maybe they did blow -- and the original owner replaced them with something that he/she hoped would not blow. I'll follow your sound advice. So I sort of swap fuses -- put the 4As to protect the speakers, and the 3A as the main power fuse?
In other somewhat un-related 3233 news: I had two TTs that I was using with my 3233 at different times. (1) My Luxman TT sits NEXT to the 3233. (2) And I have a Pioneer TT sitting on TOP of the 3233. Both remained "hot" (both plugged in to my Furman power source and both grounded to the 3233). I just easily swapped the phono inputs when I wanted to enjoy one or the other. I was getting a pronounced "hum" from the Pioneer sitting on top of the 3233. So, without an album playing I maxed out the volume and carefully, slowly lifted the Pioneer TT up off the 3233 an inch at a time -- no platter spinning. As expected, the farther away I lifted the Pioneer TT, the less hum I heard. But I did not expect to hear virtually all of the hum disappear. I had to put 14+ inches between the Pioneer and the top of the 3233 to get the hum to go away. But the hum really did vanish. Almost completely. What a nice surprise for a 50-year old unit. (The Pioneer TT sits really low and does not allow much 3233 heat to escape from its vents -- but I was careful not to "push it.") Another small victory for us vintage audio fanatics. Cheers.
