MCS 3253 Receiver question
Get that receiver straightened out and then HOLD ONTO IT!!! Don't be the dumb-ass I was and let it leave the house. I think I paid $30-$40 for the pair pictured below (3245 Receiver and 6602 Direct Drive Auto table), and it bested some of the other top name gear I had at the time - for me anyways.
Sweet! My son picked mine up for $30.00 and I plan to keep it! Just need to get my hands those schematics. I am eyeballing an MCS turntable right now for the same $30.00....
I have a MCS 3253 sitting in my cube at work. I paid $15 for it at a garage sale. It's a really nice receiver and I can confirm the excellent tuner comment. Clean all the controls, especially the function switches and tone defeat switches. If that doesn't fix it let me know if you still hear the popping with the volume turned down.
The static sound is still there after the Deoxit treatment (twice). At a loss over here!
We can fix it!
1. Is it on only one channel or both?
2. If you turn the volume down do you still hear the static?
3. Push all the Tone Defeat buttons in. Do you still hear static?
4. Is the static on all functions; FM/AUX/Tape?
We can fix it!
Hey! Thanks for getting back so soon regarding this delemma. The answer is "yes" to all four questions!
Great. This means the problem is likely a noisy transistor in the output stage. I am at home today and my receiver is at work, so I can't look at it, but from memory the output stage is a separate board located at the heat sink, about the middle of the receiver.
Buy a can of freeze spray and connect a pair of speakers you don't care about. Spray a very small amount of freeze spray on each transistor on the amp boared, one at a time and wait about a minute between each. Try to get the freeze spray only on one transistor at a time with no overshoot to other parts, just press gently on the trigger. When you find a transistor that makes the noise get worse or better when you shoot it, that's the bad one. It's going to be one of the small, black plastic ones.
I have a mcs-3253 stereo receiver.All was good until I tried to slightly adjust the power meter trimmers.Now the meters are pegged,the relay kicks in on the receiver but no sound output.
