Nice shot!
Thanks. I got lucky.
Nice shot!
What are the chances of finding silver rack handles for my 3710? Probably not good, best bet maybe a non working donor on eBay?
Excellent, glad it went to someone who could make it whole again. Enjoy! Looks like a nice strong signal on the meter...
It got a partial selector shaft transplant, and was successful, except the donor knob is from a silver version.
How the heck did you do the shaft transplant? I have a few that could use that.
I had a similar tuner with a bad power supply, so I swapped only the part needed with it.
I had to pry apart the little metal tabs on the front of the shaft housing to swap it out, but that was a lot easier than soldering in the whole board that the selector is attached to. :yes:
just grabbed a full set of these from the goodwill site in my area... MCS 3710 tuner, 3563 cassette deck, 3865 amp, 8265 speakers and a 6700 turntable.
weak pics, will add more after I pick them up and get them home:
I have the same problem with my tuner. So, the needles were just stuck? Which screw did you loosen?Alright! Both meters now working. Measured the meters with an ohmmeter - both deflected and stayed deflected. Stuck. Took the faceplate off for cleaning, four screw holding in the meter assy. Removed the entire meter assy, including the lamp holder, popped the faces off the meters, and loosened the screws a bit, until the needles moved back to resting position, then just a scootch more. So far, so good. Whole lot easier to tune with working meters.
Now, where to find a shaft and knob?
