While reading the paper published by ESP, an innocuous error was noticed. The link to the paper was given by DrWho in message #26 and is
http://sound.westhost.com/tsp.htm
ESP gives the formula for the volume of a cone V=pi*r^2*h/3 and while that formula is correct in and by itself, it is improperly used here. The reason, the volume in the loudspeaker cone is a frustrum of a cone, not a cone. The correct volume is h(B+b+sqrt(Bb))/3, where B is the large area of the cone, b is the smaller area at the dust cap and sqrt is square root. The volume of a cone can be re-written as V=Bh/3.
The difference is about 28% in the volume of a 15 inch cone which will have no effect on the calculated Thiele/Small parameters but shows that one can't always trust that which is written in so called 'white papers'. A 28% error in Re or Fs would have more serious consequences.
Such errors are not uncommon. Some are actual errors on the part of the author and some are the result of the typesetters, the latter showing that proof reading is mandatory.
Many years ago, in 1975, an error in a paper published by none other than Paul Wilbur Klipsch was noticed. Upon meeting Mr. Klipsch, I approached him with that discrepancy, to which he chuckled and took my paper upon which he made a note. The whole story can be found in the following link of which there are two pages, the second being accessed by the famous Klipsch BS pin.
http://www.ln271828.net/exponent.htm
As stated earlier, this error is of little consequence and I am no exception to the rule. Even something as innocuous as a misplaced decimal point can have catastrophic consequences. My dad was a mechanical engineer and as a kid, I had a habit of nibbling on erasers. To cover up my habit, I'd smooth the eraser on something rough but my dad noticed my pencil erasers were prematurely worn. I told him I made mistakes to which he replied, "If I made that many mistakes, the bridge would collapse."
