On the right track, Murray. I'll add a bit more since Dave and I have been corresponding offline.
Dave, I'll assume you know that you are connecting the variac between the AC outlet and the amp. The amp is plugged into the variac, which varies the AC input voltage to the amp (Vari-AC, get it?;-).
Also, I'll clean the tube socket contacts _very_ well and make sure they are tightened to ensure all the tube pins are being contacted well. No need to try to take readings if there are mechanical contact problems to begin with.
The trick to confirming proper bias after rebuild:
- First, make sure that the power supply voltages are in spec with the variac set to about 117 or so. Generally, I'll monitor the high voltage power supply as I bring the amp up on the variac. I do not trust the little meters in most variacs for accuracy so I'll switch over and check the AC voltage once the amp has been up and running and the high DC voltage is at spec.
**Warning**: Be aware that if the old power supply caps are still in place, the amp may _not_ get to spec or you may have to crank the variac way up to get the high voltage rails in spec. That is, you are reading waaaaay higher than 125vAC when you check the AC voltage. Don't proceed with the following if this is the case. Shut it down and rebuild the power supply. ********
- Next, let the amp cook for a bit - 15 minutes. If the old coupling caps are still in the output stage, monitor the big tubes for red-plating. I keep my hand on the power switch - for good reason. Not a good idea to leave the room, then......
- If all is still ok, then I will set up the DC voltmeter to monitor the plate voltage of the output tubes - pin 3 @ 430V. Adjust the variac so that you get this reading on the meter.
- Then connect the positive meter probe to pin 5 and you should have something close to the -46vDC there if all is well.
As I am sure you're becoming aware, we're dealing with rather high voltage on pins that are close together. The typical meter probes have lots of ways for things to slip and cause all sorts of arcing/shorting problems. I hate it when I'm almost through and then slip the probe across 2 pins. Some of my probes still carry the scars of my inattention.
To help with this, I have taken to using a set of really cool Fluke probes with little wire pullers that you can slip around the tube lugs and they'll grab it. See them here:
http://www.web-tronics.com/surpinclipac.html. They also have long, flexible shafts so that you don't have to stick your hands down into the chassis when moving the probes around. This helps with the number of times you have to shut the amp down to reach in and move an aligator clip-type probe. Note that these require the pretty standard probe wire system that Fluke markets.
Hope that helps.
Cheers,
David
