Mechanical fuel pump...or replace with electric
beat_truck
Addicted Member
'83 Dodge pickup 225 slant 6
The previous owner had a generic electric fuel pump hooked up in the rear of the truck by the gas tank, plus the mechanical one on the engine block was still hooked up and looked new-ish. Who's to say why.:dunno:
The truck ran OK until the carburetor started leaking gas from one of it's gaskets, so I rebuilt it, replaced all the rubber fuel and vacuum hoses, fuel filter etc. I got rid of the generic electric pump and replaced the mechanical pump on the block with a new one. The truck ran great for about 1000 miles, but the new fuel pump seems to have failed abruptly, but I haven't torn into it yet
The pump has a lifetime warranty, but should I bother? Are they failure prone or did I get a dud? I do know that the diaphragm can leak gas in to the crank case and cause problems. I've seen it happen twice.
Thoughts?
On a side note, I put a new generic electric pump in another carbureted vehicle before, and it crapped out within a few hundred miles, too. Gotta love some of the junk parts available today.:rolleyes:
guessing it had some issue with the fuel draining back to the tank, making for hard starts. If the check valves in the mechanical pump are dead it'll do that. Adding an electric would get around that, but there really isn't any point in having both.
Mechanical pumps are usually pretty reliable, but they may not have a lot of part turnover now. No telling how long that sat on the shelf before you got it. Also not impossible its not ethanol fuel compatible. Personally i'd probably put another mechanical on there and run with it.
Could have been to address vapor lock.
Most things I've seen suggest the pumps can be run in series as long as it is a low pressure electric pump.
Redundancy is not bad for reliability and I have done the same thing for high end built mussel cars. I had my 67 mustang fastback die one night as I got on the freeway and punched it when the mechanical pump died. If i had an electric one also I wouldn't of had that problem and had to wait for a tow.
It's a lot nicer and easier when the electric pump charges the line and primes the mechanical pump at starts. I had high performance engines and they like a smooth constant pressure to perform their best. Think of it like a amp clipping when you punch it and you don't have enough power but it's still playing music. The same thing happens with an engine when you punch it.
I know you do not have a performance engine, but they all need gas. Cheap new or rebuilt pumps will fail all the time, and I'm sure they don't make a good race one for this engine. The last owner overcame this with redundancy and giving the mechanical pump an easier life by not needing to work so hard to feed the engine..
Modern gas evaporates out of the bowls faster than old gas. So for an occasionally driven vehicle electric is nice. If you use one do either put an oil pressure interlock on it or use something like a WCVW fuel pump relay to shut the pump off if the engine stalls. The WCVW relay is nice because it will pre run the fuel pump for a few seconds before you hit the starter if you let it.
Cheap genaic parts are allwise the problem , in general pumps push better than pull any leak in the fule line is a problem for the pull type and if a push type is added it leaks not a lot but kills gas mileage all chech for any hidden filters and very important is that the tank is clean if rust blocks off the tank put let the pump will fail too
The last time I drove the truck, I drove it 70+ miles, and it was perfectly fine. A few hours later I left the house, and started up a steep grade about a mile away. It just lost all power like it ran out of fuel. I pulled over and it would idle for a bit, but would die if given any gas.
I highly doubt it's hole in a line. As I mentioned, the rubber lines are all new and the steel lines look good. The tank doesn't have rust in it because it's plastic. Plus the old fuel filter was still clean inside. Gas mileage was 18 -19 mpg average.
I hate electric aftermarket fuel pumps. Factory pumps, electric or mechanical, should last a very long time. Maybe there is trash getting in the pumps. I would take the tank out and inspect it, and clean thoroughly is no rust is apparent.
Of all the cars I’ve worked on I’ve never known a 225 fuel pump to go out, that’s got to be a rebuilt engine with the wrong rod that pushes down on the fuel pumps lever !!!
Allot of people just don’t know their interchangeability....
As do I. Especially Airtex pumps. They are JUNK, and I won't touch one even though they are usually cheap and have a lifetime warranty. The counter guy at Napa said that they quit carrying them because of all the returns.
My friend went through 3 of them in his Chrysler. The one I put in our old Blazer could be heard with the engine running. I read in the reviews on one site that one guy was on his 5th or 6th one in his Chevy pickup. He kept replacing them because they were lifetime warranty. I think I'd have given up and changed brands after the second.:no:
Dropping the tank is annoying enough to not want to do more than once. I put a Walbro in my Towncar, its been fine. Not obnoxious and it hasn't needed to be touched since it went in. I replaced it when the fuel tank rusted and started to leak, the OE Ford pump was still actually working at 25 years old.
If you do decide to go mechanical, I can say that at least on an old Studebaker an original Carter pump with a new diaphragm is way preferable to an aftermarket Airtex POS. No experience with a 225, I've worked on two of them but never had any fuel pump issues.
I don't have an original pump, and I have no Idea if they are rebuildable or not. By '83, I'd suspect not. I didn't come across a rebuild kit available, either.
The last few in-tank pumps I replaced, I used Carter. I don't remember what brand the one I put in the Dodge was, but it wasn't Airtex. That doesn't mean it didn't come from the same factory, though. I think for now, I'll probably just replace the pump with another since it is under warranty. If it dies again, I'll definitely go with a good name brand of electric pump, like Walbro, Holley, etc.
Unrelated. My old Volvo 240 wagon came from the factory with two pumps, one in the tank and one on the frame rail. The car started becoming harder to start, but only below half a tank of gas. Otherwise it ran perfect.:idea: It turned out that the pump in the tank had died. Of course was an aftermarket Airtex POS. I was surprised the car ran as well as it did (actually at all) with a completely dead pump in the line.:confused:
Back in the day I bought a Bap/Geon electric aftermarket pump. Never had a problem with it. See if they still make 'em.
If you go with a electric I would recommend either a Edlebrock or Holly Rotary Vane fuel pump. Keep the PSI around 6 psi and should work fine. I have had a few 225 engines over the years and never had any fuel pump issues with any after market mechanical pumps but Carter would be my preference.
