DaveVoorhis
Addicted Member
I find this comment offensive.Welcome to the New Millennium and the Age of Identity Politics. People are now offended faster than your speakers can handle transients!
Joke!
I believe the bass units are sealed cabinets, while the midrange/tweeter units are infinite baffle design. So yes "infinite baffles with sealed cabinets." Check it out.![]()
My speakers have a HF contour that allows you to control that roll off.
As for me, I've never used in-signal path EQ in the main system since it runs full range. On the other hand, I've used a number of room treatments to provide linear bass response in the bottom couple of octaves.
My forest of bass traps and careful speaker placement has resulted in a very linear response in that region.
Hi-fi is sitting listening to someone play a piano at the Cannabis Club.
Don't you want a flat response in that domestic room? The greater the deviation from flat response the more a speaker becomes a producer of distortion rather than a reproducer of music.
Yep , that is the aim , but speaker designers have no idea what the acoustics of my room are..so a specification chart does not tell me much about how they will sound , regardless of how flat their response measures elsewhere..
Infinite baffles with sealed cabinets? Is that similar to a time paradox or galvanic isolation.... or a vegan wolf?
Regards
Mister Pig
Does one consider the dropping off or a bump in certain frequencies distortion? I never really thought of a speaker that failed to have a flat response as producing distortion.
I direct your attention to Quad ESL 57's. They are the only speakers I'm aware of that can reasonably and semi-accurately reproduce a square wave. That ability in and of itself is one of the reasons Quads have such superb midrange response as reported by everyone who listens to or has heard them.
Are they? Lol. Have you heard a first watt J2?Actually First Watt models are mostly mid-fi - they are very dependent on speakers parameters, and in many cases sound poorly. See example in latest issue of Stereophile.
Hi-fi. Is not plug and play.. If anything that is what midfi is. You have to match components.. synergy is key. You don't plug a SET amp into LS50s because it won't work. You don't plug your turntable phono leads in to the CD connect on your pre-amp.. because it won't work.. lol. Things have a place and a purpose. Just because one thing is not suited to another doesn't mean it's crap.From hi-fi I at least expect ability to work with mainstream speakers like ls50. When amplifier cannot outperform Chinese tube unit - this is a bad sign.
Dunno about the originals, but Walker demonstrated this on his then-new ESL-63s in 1982 (paragraph 6), which he always said were superior to his original design. I like mine.
http://www.stereophile.com/news/121503walker/
The hobby has turned into a synergy stew. Not all eat stew.
I don't obsess whether a cable or new component will be an epiphany. Every ones' mind runs in a different direction. That's why there's so much gear on the used mkt. Mfgs are always touting a "new break thru" to boost sales. There's no shortage of choice.If you mean that a significant portion of hobbyists believe that their system is more than the sum of its parts, then the only reservation I'd have with your statement is the "turned into' part. I recall synergy being emphasized as a strategy/goal very clearly in the early 80's.
I had a college professor once who insisted that you show your work on exams so he could take points off for compensating errors even if your result was correct. In the audio world, the equivalent seems to be a "fidelity" proponent criticizing the methods of a "musicality" proponent.
Myself, I'm in the musicality camp, but, perhaps curiously, I think that high fidelity is usually the faster way to get there, up to a point, at least.
Is that close to what you meant, or am I way off?
