midrange replacement for Diatone DS-251 MK11??
kyray
Member
Just picked these up. Missing a Mid- Need a midrange that works well these. Any suggestions?
These seem to be highly regarded by most-Worth restoring? Says on specs,it's a 5 cfm corn type.
Anything I should look for(8 ohm & same size obviously)??
System 3 ways and 3 speaker acoustic air suspension system
- Book shelf type
Use unit etc. For low-pass: 25cm corn type
For high regions: 5cm corn type
For high [ super-] regions: 3cm corn type
Rated impedance 8ohms
Play frequency band 40Hz - 25000Hz
Output sound pressure level 91dB/W
Crossover frequency 2000Hz, 10000Hz
Level control Step type 3 position (3dB)
The maximum input 40W
Dimensions Width 315x height 525x depth of 240mm
Weight 12kg
I think this is a pic of the midrange. I emailed Parts Express & they said they had no cross reference for it. Just wanted a "similar" mid as the rest of the speakers are decent.
