I get migraines quite frequently. I've been lucky in that excedrin migraine (or a combo of tylenol, another nsaid and caffeine) usually will take care of it.
Ocular migraines usually have no pain but lots of auras
Guys-MAKE SURE these migraines AREN'T masking something else...In MY case, it was VERY high blood pressure, which led to a small stroke in 204. Yer ol' Bod MIGHT be tryin' to tell you somethin', & you ain't a-listenin' to it...
Ever get a post-coital headache?You will swear(pardon the pun) you are taking a stroke.Problem with them,after the first one,you need to be checked for an anuerysm.Same presentation.
All right, seeing as how we're all being honest & sharing our agony together, did anyone else ever wanna just say "F!ckit, I've had ENUFF..." & think about doing yrself in while in the clutches of one of these horrible episodes ? I know I did, lotsa times...
Sorry to hear that so many folks suffer from migraines!!!
I rarely get migraines anymore. I used to have them so often that I should have invested in the pharmaceutical companies. After years of getting migraines, some of which would last numerous days, with sensitivity to light and sound, nausea etc, I finally started to identify things that would trigger them for me and now avoid them. Imitrex was one of the few prescriptions which seemed to knock the headaches out, but left me feeling groggy and/or hungover. Before that I had tried narcotic type pills that rarely did any good, Ibuprofen barely made a dent.
I tried the heat to the neck thing which helped, also tried the immerse the whole body up to the neck in the hottest bath I could tolerate. I found staying in a completely dark room helps too.
Now when I start getting one of the rare migraines I take two benedryl tablets and a vicodin (now vicodin does not make me groggy at all, quite the opposite it's like drinking 10 cups of coffee). If taken early enough this combination will stop the onset of a migraine for me.
But the biggest help for me has been avoiding items which triggered the migraines. MSG is one chemical that has been found to trigger migraines for lots of folks, so make sure to avoid it like the plague. You would be surprised how many prepared foods at restaurants and or in the grocery store have added MSG. The second food item which I had to eliminate was aspartame aka NutraSweet. I used to drink diet sodas all the time without realizing that they were causing the majority of my headaches. If you read up on the artificial sweetener you find that your body turn it into methanol or something like that, not good for the brain.
I had also found that there were smells that could bring on a headache too. For me the smell of diesel exhaust can cause an instant migraine. Another smell and/or pollen is that of "Star Gazer" lilies. It took me quite awhile to realize that every time there were flower arrangements with these particular fragrant flowers at my workplace I would end up in excruciating pain.
From my experiences with eliminating certain items from my food and surroundings, I have come to believe that most migraines are a type of allergic reaction. (therefore the benedryl cure). I strongly recommend keeping of a record of things you come into contact with before a migraine starts, then if you find a pattern eliminate possible triggers from your diet or environment.
I've been getting them since the early '80's. Used to take some heavy-duty painkillers whenever I got one.... that is, until Imitrex came out. Changed my life. Now the biggest thing I have to worry about is getting one in my sleep. I usually wake up and notice the aura thing is happening, and I have to stay awake and sit upright until that passes (because it will just go on and on and on if I go back to sleep, and then I end up with a really-BAD headache when I wake up again). That aura is a pain in the ass, especially when I'm on the computer or watching TV (because I have to stop), or when I'm driving or about to drive. But ultimately, it sure could be a lot worse. I used to get some really-nasty migraines in high school back in the '80's that would just debilitate me (I took a lot of sick-days, although I have to admit that not all those migraines were legitimate - It was a great excuse to get out of school when I really-needed to). But Imitrex definitely saved me. I used to use the disposable nasal-spray things, but I eventually switched to the pills (The pills may take a little longer to kick in, but I don't mind - That spray tastes nasty - It always drips down the back of your throat.... Yicch!).
