mikeski
I need input
So, it has been decided. Thanks to Kegger for the design and interesting tube choices. I am going to build the amp from this link, post #7-> http://www.audiokarma.org/forums/showthread.php?t=321036 and will post an updated version of it when mine is working properly.
I have the A300 Iron
Tubes will be....
a 5V4G for the PS. They come in bottle form.
a pair of 6BL8 for the "direct coupled gain to splitter tube". This tube was designed to be used as a frequency changer in TV receivers.
a quad of 6JB5's. These look like R2D2. This tube was designed to be a vertical deflection Amp in a TV.
I believe I am looking at 20wpc. And it's a clean slate. I have no chassis to start with.
I should probably buy two set's of all the parts. The first to use as a mule. The second for the build of the pretty one.
Tubes will be....
