Context: MC34B driving a pair of Bohlender Graebner 28.1 planar magnetics after an active digital crossover at 250Hz - no passives between amp and driver. The BG is somewhat 'cool', and I've been loking for extra 'warmth' without losing detail. Things I've tried in the last 6 months:
6H30pi at input and/or phase splitter positions
Etched detail, closer to a SS sound. I've heard this tube sound good in other circuits, and I suspect it's not getting the heater current it needs. Back to the JJ ECC83S.
JJ KT77 replaced JJ EL34
Smoother midrange, extended top end.
EH 5751 replaced JJ ECC83S
Less gain so less hum, which is good - don't want to feed any more LF to the drivers than is necessary. Also more delicacy - something like the change from pentode to triode.
GE JAN 12AT7WC replaced EH 5751
Tried this after reading the El Cheapo thread on the Decware forum (thanks Eli and Jim ) - the basic idea is that PP amps cancel most of the 2nd harmonic, making the 3rd dominant. Perhaps a fundamental difference between SE and PP amps? The story goes that the 12AT7 has overall higher distortion than other 12A*7 types, but it is mostly the 2nd harmonic and after PP cancellation the distortion 'waterfall' sounds better. It worked for me.
Jensen Copper/Oil coupling capacitors replacing Solen/SCR MKP
Wow. This is the single largest improvement I've heard from all the tweaks. If you do nothing else, my recommendation is to find room to fit better coupling caps. The circuit is good enough that this is a reward.
David
