Absolutely, that is step one of getting T&S from DATS which is a two step process. First you run the impedance sweep, then you add the mass and measure the Vas.
From the user manual:
a) Click on the "Measure Free Air Parameters" button at the left of the DATS V2 window. You should hear the sweep and then see the impedance response plotted on screen similar to Figure 1. The impedance magnitude is shown as a blue plot with the phase response shown in red. Several of the speaker's free air parameters are displayed in the Parameters Bar at the right side of the screen. The bar at the left side on the window is where you set the impedance and frequency limits for the current display.
b) Measure the driver's Vas. Once you have measured the speaker's free air parameters the "Measure V(as)" button becomes enabled. Select one of the four methods to measure the Vas at the upper right side of the DATS V2 screen.
