davstev
Well-Known Member
Hi all,
I have a nice pair of Minimus 7w’s that weren’t working, and I also happened upon a nice pair of replacement speakers for cheap. The replacements are a perfect fit and look great too.
The new woofers are 4 ohm instead of the original 8 ohm, for which the existing crossovers were designed. Currently the sole cap in the crossover (which I think is for the tweeter) is at 4.7uF/50v. As I understand it, the original 8 ohm woofer had no capacitor in its path.
For two reasons, I need to redo the crossovers: firstly, because the non-functionality of the speakers as I found them may have been due to a faulty crossover, but also because I plan to put a 4 ohm speaker in.
Can anyone advise what an upgraded or revised crossover for this 4 ohm woofer setup would be? Is there a simple modification that I could do to the existing crossover, or build a new one from scratch? Upgraded crossover? I am inexperienced in figuring such electronic things out but good at putting it all together in the end. Feeling a bit lost at the moment. Thanks for any guidance.
(Pics below show the new woofer in place, and the original crossover.)
