Raynald
Addicted Member
Picked these up from someone I used to work with in my audio days. A few cosmetic issues but pretty nice overall. The major problem is the complete lack of front tweeters. Everything else seems to work, though I discovered one of the woofers has a buzzing problem at some frequencies.
Phase one: Swapping the front tweeters around to the back. I ran into my former Mirage rep and he confirms the back tweeters are the same as the front. That will involve prying off the side panels and pulling the socks off at which point I will also pull the woofer and have my speaker tech sort it out. This will result in a full range speaker with a Bi-polar midrange which should be pretty nice.
Phase two: Find replacement tweeters. My ex-rep agrees with me that getting a perfect match is not critical, just something with similar efficiency and frequecy response. Not sure if a difference in impedence will make a big difference in such an inefficient monster on the end of a very complex x-over. The ideal might be a lower model Mirage 90 series that used a similar mounting plate. Otherwise making a mounting plate should not be a big deal. The tweeter is recessed a fair bit so I have room to work with.
Fallback plan: I now have lots of spares for my existing M-3si !
Does anyone have a lead on someone who might have some Mirage spares or at least the specs on the Msi series tweeters?
