Mission 751 - Thoughts?
Just listening to Elvis singing Fool Such as I, and both his voice and the bass from the Jordanaires, who's name escapes me right now, are clear and distinct, but still musically cohesive. Nice trick that so many "better" speakers don't do well.
BTW, this Elvis "Hitstory" collection sounds VERY nice.
Nice, Missions have have always had PRAT which makes them very musical but
They certainly don't like garbage being fed into them
. That's how I recall the newer Missions. The originals were a little more forgiving.
Nice, Missions have have always had PRAT which makes them very musical but . That's how I recall the newer Missions. The originals were a little more forgiving.
"Newer" I guess is a relative term. :)
Weren't these released about 25 years ago?
To clarify, it's not that they make bad recordings unlistenable as some speakers do. Rather, they make sure you hear the difference between the two. A fair compromise, IMHO.
Newer is definitely relative:lmao: Kinda dates me doesn't it. :D
Hooked them up to a Luxman LV-105u, recapped and retubed, and what a difference. Just sensational sounding.
if you buy these great speakers on ebay just beware of dried up ferro-fluid on the original 751's, I've had three pairs and two of them had gone bad resulting in severely reduced output & power handling.
In some cases they can be disassembled and cleaned but one pair I had were so far gone that removing the diaphragm was impossible without damaging the voice coil.
to be honest, I'd avoid any speaker using ferrofluid, including the 751's, it's just used as a cheap way of bumping up tweeter power handling and damping poor coil/diaphragm assemblies. It will dry up one day and you will find it nigh on impossible to save your 751's
Castle use ferrofluid as well :-(
Weren't the 751's the floorstanders with 2 8" transparent woofers a tweeter above. the first model had sooo much bass in room that the revised model put the ports on the front? They listed for $1899.00 new but got a rep for being unreliable. If those are the models you seek check Saturday audio exchange last time I looked they were asking $499. for a pair.
Those could be the 765i your talking about. Been listening all day on mine. Tweeter above 2 8" woofers and dual front ports below the woofers. I am very happy with mine and so are the Tubes!
Opus
ahh, 765i thanks fr the correction. I still don't know why I did't buy them back in the day I think back then I counted the amount of drivers in a box instead of just trusting my ears and I think I may still have the same problem. I have no doubtyour enjoying them.
I am enjoying them a lot. They are hooked up with the Golden Helix speaker cables from Mapleshade. 9' apart and 10" from back wall. Imaging is great and the music is balanced very well. Between the Tube Amp and Tube Pre and Sony Playstation 5501 the sound is very much Turntable quality. Can't ask for much more.
Thanks,
Opus
Unfortunately my Mission 751 tweeter died with that ferrofluid problem. The driver was a 8 Ohm (!) 51-HFLM1 peerless with partnumber 811839.
Can anybody help with a replacement?
The plastic grill fitts to the 5,7 cm Tweeter. Perhaps i have to shorten, which i want to avoid. How to discover which part of my crossovers are eventually mashed?
Here
https://www.hifi-selbstbau.de/index...3&catid=51:fertiglautsprecher-umbau&Itemid=82
some people replaced it with a CarPower DT-284S, which is no longer available.
Most easiest way would be to find a very good tweeter with 5,7 cm calibre and just clipping it into the plastic grill.
Perhaps someone has got the fine idea for this task?
I use 4 Missions on a Marantz 4270 and the Mission sound great (classic: orchestra & voice) with this receiver. My goal is to save this 80ies sound or to make an upgrade to this tweeters.
Thanks a lot for any advice!
Later, Peter
Hi
You can try just replacing the tweeter voice coil only , it size is 25.5mm+/-1 or 1 inch...there are quite a number of 8 ohm tweeter voice coil to choose from on ebay . ...
I did experiment with the replacement voice coil on my 753 tweeter to see it fit..honestly they do fit very well..as you can see my is 4ohm. And the test subject is 8 ohm. No other test was conducted due to the different.. what you have to do is to reuse the black bracket which house the diaphragm and voice coil.
Here
Later, Peter
Hi
Mission 753 tweeter Mod 1.jpgMission 753 tweeter Mod 2.jpg Mission 753 tweeter Mod 3.jpg Mission 753 tweeter Mod 4.jpg Mission 753 tweeter Mod 5.jpg Mission 753 tweeter Mod 6.jpg53-hflm2.jpg
P.S.......the Red plastic bracket is use as example as None of my Mission 753 and 751 tweeters is defective , but will be use for future project.
Sorry for replying to a old thread , this might be helpful to others looking for a solution to his/her Mission 752 / 753 Tweeter Hf unit part 53-hflm2 or Mission 51-HFD27/ Tweeter .
Thanks for reading
Regards
Peter
There is a pair of these for sale near me and I have some questions:
Do you think they'd pair well with my Sony V333ES? It's a digital amp, so far from tubes!
About what are they worth?
This thread is helpful in many ways. If and when I look at the pair near me, how can I tell if the ferro-fluid (and whatever else) is good?
I have AR18 speakers. Will these Missions be a big improvement?
Hi, I have a chance to get a nice set of real wood veneer in mint condition Oak Mission 751 Freedoms. I am a bit worried about the comments regarding loss of detail in the silk dome compared to the original. They look really nice. The other choice I have at the same price and condition is the newer kef Q100. I have q150s already so was interested in trying something different.
Does anyone have experience with Mission 751 Freedoms?
Thanks in advance!
