Mitsubishi DA-M10 meter
Does anyone have a "user manual" for the Mitsubishi: DA - M10, DA - P10, DA - F10? I just purchased this set and don't have the manuals so I'm not quite sure on how to hook it up. Any help would be greatly appreciated. Thanks
I recently bought a Mura model APM-618 power meter and need to be sure how to hook it up to my Mcintosh MC250 and Wharfedale W-90 speakers with an NAD 1600 preamp? The Mura has both RCA jacks and screw connectors marked amplifier and speaker on both right and left channels with a switch for 4ohm to 8ohm. The MC250 has RCA cables going to the preamp and "monster wire cable" going to the speakers.The Mura connections are not mark as to in or out and I'm not wanting to experiment with connections and can't find any info on this Mura Corp. model APM-618 stereo power meter? Can anyone help me to understand this hookup?
Greetings To All !
I am brand new here, found this forum while doing research on some audio gear I acquired recently. I have a Mitsubishi DA-A7DC Audio Power Amplifier and the mating DA-M10 Meter Head.
I became aware that these two units can be bolted together to form one unit. From the few pix I have seen as well as visual inspection, it appears that there must have been some sort of 'fastening plates' to facilitate mating these two units mechanically.
Does anyone have a picture of the original mounting/mating hardware that is required ? I would appreciate very much if someone who may have this hardware would share a picture/pictures of what they look like !
I am planning to have some made and it would be nice to have a pictorial image of the originals.
Many thank in advance for any help offered !
Best wishes, Mark..
I too am looking for the same. I do, however, have the Service Manual for it if you would like a copy, I have it in PDF format, just let me know.
Best regards, Mark..
The components bolt together with a pair of rack mount ears. They may be a little hard to track down. Here is a picture of an amp with the ears in place. Either the pre-amp or the meter bolts up to the front of the amp making a single unit (sort of). I see a couple of amps on the bay right now with the ears attached.
https://www.pinterest.com/pin/303781937342575304
Terry
Terry
Good Morning Terry !
Thank you so much for enlightening me on the correct method of fastening the two units together ! I really appreciate it ! Yes, I did see a pair of these on 'the Bay' a few days ago but $74.00 is a lot more than I'd care to spend so I will continue with my plan to fabricate my own, I am planning to stop at a sheet metal shop today to have them sheer a couple of pieces of 1/4" aluminum plate to the appropriate size to facilitate interconnection. I'll keep an eye out for the original handles with a fair price also for future reference.. Take care, have a great weekend Terry !
