Mitsubishi DA-M10 Replacement meter
Mjclemm
hello guys, been awhile........, does anyone know where I can get a replacement meter for a Mitsubishi DA-M10 ? Or can they be fixed ? The meter is dead, I switched the power from side to side and it still wouldn’t work..... thanks in advance for any help..... Michael....
And jiggle the selector switches on the side. Mine were always causing flakiness on one side.
the rca jacks on that tend to be touchy
try reflowing the solder on the jacks
I checked all the joints , boards etc, then I physically changed the meter from the good side to the bad, the good meter works on both sides, the bad meter did NOT work on the good side or bad side, so it’s without a doubt the meter itself. But I have no clue on how to fix it, or where to get a replacement.... if anyone here knows how to fix it or where to get a replacement it would be great..... I love the meters (replaced the lights with blue LEDs) and it looks awesome...... thanks for the reply..... Michael....
Checked that as well, i posted a reply to all I did above...... thanks for the advice..... Michael......
Ps: every site or auction that had a meter like this is sold as fast as they post them....lol....
i did the blue led's also, to match the blue on my emotiva stuff.
i didnt like the blue so went back to white
cant help ya tho, sorry
Hello Michael!
Just a question, as you replaced the VU-meter lamps: I am also searching to replace the old lamps, do you know - or anybody else - know the size?
I guess fuse type lamp, right?
Is the size 5x20mm or 6x30mm for the Mitsu DA-MA10?
From DA-M10 Service Manual only say it is fed with 7,5V, but in the manual there are no any picture of this lamp how it looks like, or what mA rating(?)
200mA? 250mA? 2W? or what I should look for..?
Do you know any source for these where to buy good replacement in different colors? Thanks in advance!
