Kahoona
Hi
I have recently gotten back a DA-C10 that helped blast me into orbit during my extended and misspent youth. I am wanting to set the Bias and DC offset and am very confused by the service manual. I have done this many times on other amps and will actually replace a couple of trimmers to make it easier. I am unable to make sense of the service manual and I know some of you have these machines ans have done this so I hope you can explain! If not perhaps someone might get a chuckle.
There are three trimpots per side 102,103 and 104, and a line level control mounted on the back of the cabinet.
Problem one:
Here are the instructions for setting the Bias
Easy enough remember that 103 sets the bias. Now we look at the DC offset instructions
Could the same pots really be used for both? I have to add that on the DC-A7 there are 2 pots each side to do large and small adjustment on the Offset. This diagram does not look a lot like the board but it is clearly labeled.
On top of this there is a pot # 104 that is not mentioned. I am guessing that in reality pot 104 does the bias and 102 and 103 do the offset but it is a guess.
Here is a diagram found on AK which does show the parts in the right places. I don't know where I found it. Sorry.
___________________________________________________________________________________
That is the end of confusion number one.
Problem one:
