Mitsubishi DP-EC2
handlesh
I just fired up my Mitsubishi DP-EC2 turntable and all is well, except the strobe light/speed indicator does not turn off unless I unplug the unit. Any thoughts about this problem? Thanks.
Do the strobe light and speed indicator turn off when you move the tonearm onto the rest and snap it into the arm holder? If yes, I had this same problem with a DP-EC1. There is an adjustment to set the position at which the 'table powers down at the end of a record after the tonearm returns to the 'arm rest. Download the service manual for the DP-EC1 from Vinylengine. The DP-EC2 has most of the features of the EC1, and the adjustments are very similar.
The Speed Indicator and Strobe Lamp will not turn off until you snap the arm into the arm rest. The platter will stop rotating, but that's it until you snap the arm into the rest. I have the service manual for the EC2.
Dp-ec2
Thanks for the responses. the stroboscope light does not turn off after I snap the tonearm into the lock position. the only way to get it to turn off is to disconnect the power cord. Also, it appears the light senser does not recognize 45 size records. I guess i have a few issues. beyond these, the table seems to work fine. thanks again for your kind assistance.
