I picked up an inoperative LT-30 the other day and thought I'd follow up
this thread over here, since this is the amazingly informative LT-30 thread with which I'd not have placed my wager. I must extend a huge thank-you to OP and Pio1980, and everyone who has contributed with excellent tech advice and photos.
So far the progress has been minimal, but the process interesting and enjoyable. I evicted a spider and a several egg sacks from under the bottom access panel, but other than that she's clean and shiny with no signs of high-moisture basement living, or a dirty/dusty environment, and only minimal signs of being previously worked on by a hack (other than myself of course.) More on that in a minute. The wire that moves the tonearm laterally was off its pulleys, but it went back on without a hitch. Surprisingly, the feet are in great shape and are not sagging to the point of the plinth touching their bases, so they were using some good rubber compared to Pioneer or Kenwood.
I had an SBS3.5 belt on hand since several of my Pioneer decks use one, so I got the tonearm lift belt swapped out as a matter of indoctrination and only lost my will to live two or three times in the process. The SM photos are truly bad and instructions typically vague, and the LT-30 is complicated, but thanks to the tips and photos from this thread, it got done in short time with minimal shifting of parts. Next time I'll be able to knock it out in fifteen minutes in case the new belt doesn't outlive me. The larger linear tracking belt seemed excellent and easily swappable later, so I left it alone. I did order the SBS3.5 and SBS5.1 belts it uses from turntableneedles.com, so I'm covered, and they've already shipped. Kudo to them for their responsiveness.
What I have now is an LT-30 with a platter that spins, locks speed, and detects record size properly, but the tonearm doesn't move up, down, or laterally from its resting position. I'd be thankful for any input.
- All the lights on the panel work and the green arrows which show left, right, and center all correctly indicate tonearm pivot position.
- From initial power-on, neither the up nor down arrows illuminate, but if I press the "up" button the "up" arrow illuminates. If I then press "down", the "up" arrow stays illuminated. There is no noise from the lift motor.
- The "start" and "stop" buttons do nothing. There is no noise from the tracking motor.
I guess the next thing I should do is look for bad wires and check solder joints. I did notice that one white wire to the tonearm base, where the lift assembly resides, got squashed by a previous technician (just as has been warned about here and in the SM), so repairing that will be step one. If anything else I should do jumps out at you, please let me know.
As has been stated, and I agree, this thing is a masterpiece of engineering and a pleasure to work on. Not a huge fan of the incandescent lamp choice over LEDs, but there's certainly nothing cheap or mundane about the design. I just hope I can get it working so it doesn't become a parts donor. It's too nice for that.
