petehall347
the brandy coffee man
i expect the 700 wont last long now ..RS has 5 of them just in case .
it typically doesn't do .or is dealt with by the amount of copper its soldered to . i am having an ongoing battle with my washing machine with triacs mounted on the board .I must have missed something - - -
How can a SMD dissipate as much heat as a typical TO-220 or TO-3p transistor that it is replacing?
I am having an ongoing battle with my washing machine . . .
yes they do . i wouldnt mind so much but i rarely use it ..seems about every third time another triac goes bad .either blown up or partially shorted .I hope that it is a battle you can win. Remember that those things fight dirty - - -
Sorry but I think that you are misleading some folks here because if they were to go end of life they certainly would announce as such on the web page and give lots of notice for last time buys. Literally 1000's of designs use these parts, so much so that being out of stock actually shows that many are still being used at such a rate that they can not keep stock, which is a good thing. Our little niche of audio repair is a drop in the bucket compared to large manufacturers who use these parts.I think you will find these might be the last runs they are doing for these transistors......I think its time to start stocking up....I know I've been ordering a lot more than I need so I always have some...
Of course they can not, people make all kinds of inaccurate statements and have very little actual design and manufacturing experience to base their opinion on. The TO-220 package will be around for ever, it is a industry standard that everyone uses. If a die gets hot, it has to have a way to remove the heat or it will self destruct, basic physics.How can a SMD dissipate as much heat as a typical TO-220 or TO-3p transistor that it is replacing?
Beef up that triac, I use those 40A ones in the metal stud package. Some use back to back scr's as an alternative to a triac.yes they do . i wouldnt mind so much but i rarely use it ..seems about every third time another triac goes bad .either blown up or partially shorted .
i cant see a problem using relays if it comes to that . another machine would be easier apart from its location .Beef up that triac, I use those 40A ones in the metal stud package. Some use back to back scr's as an alternative to a triac.
Thats an excellent alternative.....As an alternative to the MJE15032G try the Fairchild FJP5200
Yes I have to agree that SMPS are a lot more common than linear type PS in this day and age due to efficiency/size/cost benefits and requirements.Poor choice of words on my part, I should have been a little more specific, I am finding in the gear i work on, that I am seeing different supply designs and certainly are not seeing anything like the amount of TO220's being used as regs as in previous years...
I think it would be fair to say, as long as they're selling them in enough numbers, they'll keep making them...Yeah, Fairchild get overlooked for those style of packages a lot, I must admit I don't always think to look at them for an alternative....Yes I have to agree that SMPS are a lot more common than linear type PS in this day and age due to efficiency/size/cost benefits and requirements.
It really is hard to say what the long term thinking of Onsemi is, esp after they acquired Fairchild and have parts that are similar in specs.
Thank you. I checked all. RS shows additional inventory can ship on 10 days. I asked if this is true for 5 items.Mouser, Digikey, Newark, Farnell, RS Components and similar respectable companies - i.e. the usual suspects.
If they don't have any, possible substitutes have been discussed in this thread, also see my post #3
Can you go down to 30 or 28? Check voltage.Thank you. I checked all. RS shows additional inventory can ship on 10 days. I asked if this is true for 5 items.
Arrow shows as it is in stock, I bought buy they cancelled my order saying it is out of stock. But still it seem in stock in their and onsemi's webpage.
I read the whole topic as well as your suggestion but I have some 33, so I need 32.
