MM or MC Setting
Klipshman
Well-Known Member
In my quest for another cartridge I found the specs on the AT440MLa a mite confusing. Not that 1mv makes a lot of difference but some places show the output as 4mV and others 5mV. Either way that's a lot more than I expected from a MC cartridge. I thought the criteria of a MC cartridge was that the output was <1.0mV and this one is way more than that. The impedance is listed also as 47K.
I have an Emotiva XPS-1 and not sure if you'd use the MC or MM settings since this is a MC cartridge but the specs are more like a MM cartridge.
Sounds like it is a high output MC and you can use the MM setting on the XPS-1.
The 440 is a moving magnet.
It will hum like nobody's business on the MC setting. I accidentally did this once with a Grado Gold and the XPS-1.
