Uncle Bambi
Funky Tut
I finished overhauling and re-capping the AU-D7 chronicled in a different thread, and have discovered a perplexing problem. I did not test this functionality before I worked on the unit, so I do not know if it was per-existing or if I introduced it.
With a TT attached to the MM input, the right channel is missing. If I select the MC input, both channels are present but muted and fuzzy sounding. If I leave it on MM, I can get the right channel to play if I turn the "mode" knob from "stereo" to "L+R". I've cleaned both the input jacks as well as the controls. So, the signal is coming into the unit, and is getting lost somewhere along the MM path.
Any ideas?
Any ideas?
