M Jarve
Audio Geek and NGE Freak
In another thread I posted about an RCA console I bought. I've already begun modding it- I removed the amp and will be reconfiguring it as a stand-alone unit. I've already purchased new speaker and input jacks as well as a power switch.
However, the input circuit on the power amp has no coupling caps in series between the input terminals and the G2 pin. I am assuming that this is a necessary component. Right now there is just a 10KΩ resistor between the center conductor of the input jacks and G2, and a 1MΩ resistor between the center conductor and the chassis. Is there any value cap I should be looking to put in there? Or, would it be safe to rely on the coupling cap in the source component (CD player in this case)?
I tried locating the caps on the pre/tuner portion, but I can't actually see where the coupling caps are. It looks like it goes 12AX7-> volume-> bass/treble-> balance-> out to amp.
Any recommendations would be helpful.
Attached is a pic of the resistors I described above.
