slayer44
Well-Known Member
Greetings All,
I was gifted this amp and was told it had issues. I put it on the DBT first and no problems there. Powered it up and relay energizes quickly. I then checked for DC at the speaker terminals and discovered that the left channel was reporting rail voltage! (51V). I then checked all the voltages at the important points (differential was high. Around 15 V)
I then followed the troubleshooting instructions from the 1200 manual and measured normal range at the speaker terms BEFORE the relay clicked in and get about 118mV. Once it clicks, it goes back to 51 volts. I hold the relay open and get do not get 51V at the terms. Does anybody know what in the rectifier board can cause this? (I am assuming it's the rectifier board) I just got this this amp 3 days ago and it is all I have checked so far, but any insight is welcome. Without an answer from my Marantz gurus, I will pull the rectifier board and check all those components. I can deal with the amp board once I get the high DC figured out.
Also, does anyone have a BOM list to repop these amps? Modern transistors would be especially appreciated.
Thanks for reading.
Thanks for reading.
