VA1DER
Member
I just completed a restoration of a Realistic STA-120B which called for replacing 18 of the notorious Hitachi 2SC458's. Though I try to replace as little as possible in a restoration, I am in the camp that considers this a shoot-on-sight transistor. Replacing this many called for a modern sourcing strategy. There are a lot of threads talking about replacements, but the transistor landscape has changed a bit and some replacements are hard to find.
By modern standards, the different ranks and noise specs of the 2SC458 equate to six different transistor types today. I simplify this a bit by not bothering to differentiate and replace every I find with low noise substitutes.
Onsemi KSC1815YTA:
This transistor is pure magic and the driving influence for this post. My STA-120B after restoration has noise more than 120dB down from signal with these beauties in the tone amp.
I sourced this originally due to Dick Kleijer's excellent work on ultra low noise transistors.
HAVE NOT YET USED MYSELF - I've included this as something to look into for those who have no stock of 2SC2240's, based the same work by Dick Kleijer. The 2SCR533PFRA from that list turned out to be the lowest noise transistor I've ever seen.
SOT-89 Conversion
The 2SCR533PFRA has been an almost magic replacement for me, but it does require some work. SOT-89 is not naturally tenable for vintage restorations. I use it with:
I use .6mm right angle headers when the through-holes on what I'm working on are large enough. Many aren't quite large enough for .6mm square header pins, so I use .4mm gauge. I can only find long .4mm gauge in .05" pitch and straight, so I pull every second pin when I use these, and then bend it right angles after.
The finished product.
For those who don't do SMT yet, SOT-89 isn't terribly hard to solder if you have a steady hand. I purchased an inexpensive pencil hot air gun and some 63/37 solder paste and it makes short work of it.
| 2SC458 | nominal hFE | Replacement | Notes |
| B | 150 | Onsemi KSC1815YTA | Noise figure 1dB typical at 10KΩ 1KHz, Rbb not stated |
| C | 240 | Rohm 2SCR533PFRA | En = 0.465nV/√Hz, Rbb = 8.65Ω !! But Vbb = 540mV, SOT-89 required through-hole conversion |
| D | 400 | Toshiba 2SC2240-BL | Noise figure 2dB max at 10KΩ 1KHz, Rbb not stated, Almost unobtanium now, |
| D | 400 | Diodes Inc. ZTX1051A | En = 0.420nV/√Hz, Rbb = 7.84 !! |
Onsemi KSC1815YTA:
- Good dual purpose low-ish current and voltage noise.
- Good for low gain replacements or
- Good for the I-V stage in two-stage phono pre-amps when paired with the 2SCR533PFRA
- Available for about 17 cents each at Mouser
- OUTSTANDING voltage noise, one of the lowest I've ever seen, but its extremely low Rbb makes it less attractive when current noise dominates.
- Good for medium-gain replacements, most 2SC458LG's in use tend to be in this gain level
- SOT-89 so requires conversion. More on this below.
- Great for tone amp board replacements, or the voltage amp stage in two-stage phono pre-amps.
- Very low junction voltage drop, Vbe = ~540mV. This can lead it to act as if it has more gain in certain topologies.
- Currently marked as NRND, this appears to be due to a simple rebadge where it is being split into the 2SCR533PHZG and 2SCR533P5 for with and without AEC-Q101 (automotive) qual. I have not myself used the replacements as the PFRA is still very available.
- Available for 30 cents to $1 each at mouser depending on quantity
- The previous gold-standard for 2SC458 replacements. Still a good transistor, but becoming increasingly expensive and/or unobtanium
- Good for high-gain replacements
- Ok for medium gain if a good feedback network is in place, but this increases noise
- Genuine ones going for $2+ each, know what you're looking for as 95% of ads are fakes.
SOT-89 Conversion
- SOT-89 -> .1" / 2.54mm pitch header hole micro-board
- 90˚ .1" / 2.54mm pitch 0.6mm gauge R1 12mm header pins, or
- Straight .05" / 1.27mm pitch 0.4mm gauge 14mm micro-header pins (every second one removed)
