OmegaHyperio
Been a while since i posted here,
well straight the point, im working on a Marantz PM350, and i have narrowed its fault down to the negative regulated power supply (probably, might still be the phono opamp). The negative rail is near dead (-1V with everything connected)
My thought is, its either the 2SB605 transistor, or the HZ16L diode (or possibly the cap across the diode).
Basically put, i need a replacement for this transistor. I have seen the KSC1008 mentioned somewhere as a suitable replacement, but i am not sure it will work, since its power dissipation is 200mW less then the 2SB605.
Any thoughts from you guys would be appreciated.
Also, for those wondering, i am measuring full negative rail voltage across R806, hence my thought, that something shorted to ground in that circuit, or is shorting it. I removed the EQ and power meter boards from the amp, with no effect. (so they seem good), the only part still connected is the phono opamp, and i doubt it has gone bad.
Feel free to correct my assumptions!
