Modern Replacement for A798 Dual PNP
Geek
Nerd
Hi Folks,
Wish to share that I had success replacing a pesky 2SA798 in a Sansui 11000 phono stage with a BCM856BS.115 dual matched PNP from Digikey (part # 1727-5424-1-ND).
It's a TSSOP-6, so you'll need an adapter, pointy iron tip and steady hands!
Channel balance is great and voltages are within schematic spec after replacement. Sonics are close to the original.
Any other success stories or part types to share for this wee beastie?
Cheers!
Indeed a pair of KSA992 work and I have done that method (after matching them for Vbe and hfe) when an A798 is used as a diff. input pair of the PA sections of amps.... especially when I need to add a DC balance trimmer as well.
