Modern vs. Vintage bookshelf shootout
chef free
I picked up a pair of Infinity Modulus speakers the other day! I love vintage Infinity with the EMIT tweeters and I found a nice pair for only $400.. A friend of mine has a pair of Martin Logan LX16 which are similar in size and design so I took them to his place for the unboxing and a little comparison.
Introduced in 1991, the Modulus was fairly expensive at $1000/pair, it features the upgraded EMITk with stronger magnets than the original, crossed over at 4kHz to an injection molded graphite (IMG) cone 5.5", cast aluminum basket woofer, in a molded resin cabinet which allows for time alignment of the two drivers. Intended for amps up to 125 watts, this 5 ohm speaker claims a response of 80-45kHz +/-2dB and a sensitivity of 88dB @ 2.83v/1m.
Martin Logan's LX16 were only $800/pair when introduced in 2010! They feature M/L's "folded motion transducer", a copy of the Heil AMT that I love so much, crossed over at 2,700Hz to an aluminum cone 5.25", cast basket woofer in a ported, resin molded cabinet. Capable of handling up to 200 watts, this 5 ohm speaker claims 60-25kHz +/-3dB and 92dB @ 2.83v/1m.
Our listening was done in a sound treated room using a pair of McIntosh MC202 which were volume balanced to make up for the difference in speaker sensitivity. The pre amp was a C42, sources included an Oppo 95, MR80 tuner, and a Project Classic EVO turntable with an Amethyst cart by Sumiko. A Martin Logan Balanced Force dual 10" subwoofer (with built in DSP!) gave some bottom end to these small speakers. These speakers were placed at ear height on a pair of conveniently located JBL 4333's. We played all sorts of music, Zappa, Steve Roach, Skip Hop and Wobble, Johnny Cash, The Blind Boys, Montrose, Fripp and Eno, Christone "Kingfish" Ingram, Victor Wooten and more.
The XL16 have much lower bass (60Hz vs 80Hz) apparently due to their ported design. This difference was much less noticeable when using the sub. The EMIT has clearer "highs" (above 6k) and was preferred by my friend over his AMT tweeters but I heard the lower crossover point, 2.7k vs 4k, of the AMTs as giving a little more "snarl" to screaming electric guitars. Across much of the midrange these two speakers sounded surprisingly similar, we listened to a lot of vocal music and both speakers sound very realistic, even at higher volumes. Both speakers threw a realistic image, almost like wearing headphones. But the Infinity sounded "strained" and "thinner" when things got really loud; they are rated for only 125 watts compared to 200 for the ML's.
If I had to use these speakers with out a sub, the Martin Logan's would be my choice but with a sub it's a bit of a toss up, the ML's have smoother mid highs but the Infinity's EMITk have the "sparkle".
After the "critical listening" was done we played the Modulus while cleaning some records, the Infinity's began to grow on us as our ears got used to their sound. Every once in a while, one of us would remark "Hey these little speakers sound darn pretty good!"
Our listening was done in a sound treated room using a pair of McIntosh MC202 which were volume balanced to make up for the difference in speaker sensitivity. The pre amp was a C42, sources included an Oppo 95, MR80 tuner, and a Project Classic EVO turntable. A Martin Logan Balanced Force dual 10" subwoofer (with built in DSP!) gave some bottom end to these small speakers. These speakers were placed at ear height on a pair of conveniently located JBL 4333's. We played all sorts of music, Zappa, Steve Roach, Skip Hop and Wobble, Johnny Cash, The Blind Boys, Montrose, Fripp and Eno, Christone "Kingfish" Ingram, Victor Wooten and more.
As rare as these are there were 3 iterations of the Modulus mains with the first being the best, if you post a picture showing the drivers I'll let you know which you have.
Also, these were meant to be used with special stands to hear their full potential, along with the special Modulus subwoofer, all of which I've owned since 1991.
And I agree these little speakers are quite special, the only way they're leaving here is from my cold dead hands.
you might like this excerpt from Stereo Review June 1990, I recommend getting a copy of the magazine for the article.
I never knew the Modulus went through several versions. Can you share details? I guess I thought the Infinity Infinitesimals were the only Infinity's to lead a tortured existence. I guess not...! But, Infinity definitely liked revisions of various models. I shouldn't be surprised about the Modulus.
The first iteration was the only one to use an IMG curvilinear dustcap on the midbass driver, easy enough to see in pictures. The second used a concave poly dustcap, the third a coated convex poly dustcap.
I've not looked inside the 2nd or 3rd iterations to see what other changes were made but these are enough to show they were cutting costs.
ok, so here are some pics of the different iterations
1st, the curvilinear IMG dustcap is quite evident
2nd, notice the size difference in the dustcap as it's no longer an integral part of the cone area, as such it no longer needed to have the same curvilinear shape of the cone or be made of IMG.
I had a hard time finding a clear picture of the 3rd but I believe this is it
a picture of the special stands, notice the rubber cups the Modulus feet sit in, only the points of the feet touch the bottom of the cups which are suspended completely detaching the speakers from the lead and sand filled stands. The screws to hold the speaker to the stand come up through the two holes with rubber grommets, the screws are to be left about a 1/4 turn loose.
Again, these are an essential part of the Modulus speaker system, without them you're not hearing their full potential. These sold for $300 back in 1991, not exactly chump change back then, bringing the grand total of the complete system including the Modulus subwoofer to $3300, again not cheap but well worth the price.
Stereo Review must have been like other magazines, that published regional covers. My issue definitely had the Modulus satellites and the sub on the cover. There was even a cover blurb, about how innovative and special the speakers were.
would love to see that, I've only ever seen the above copy on the internet, eBay, etc
even looking into the Stereo Review archive I've never seen it, sure it wasn't Stereophile?
It was Stereo Review. Julian Hirsch did a special cover story review. A featured review, separate from the normal review section. It made me want to buy a pair, as Julian didn't often lavish praise in his reviews.
possibly a followup on a later iteration?
Looks like I have version two.
I spent tonight listening to them paired with a Martin Logan DepthI subwoofer. Played Cody Jinks, ELP, and Jazz at the Pawnshop, it all sounded great!
As I stated earlier, I've had mine for more than 30yrs.
Along with my AR XA, and Pioneer SX-1010 they were the only pieces to survive the great sell off of 2012 when my bride passed. I needed something to have to listen to music while i waited to die, lost 62lbs but didn't go see my lady so went back to work and started collecting again.
These little speaks will never go until I do.
My Modulus get used daily.
They are simply fantastic little speakers, especially when paired with a sub to fill in the bottom end.
I'll never get rid of them.
they are quite special, and in a small bedroom they work very well even without a subwoofer.
