Modified Lenco L75 Tonearm choices?
apachef1
Well-Known Member
Anyone have experience with Modded Lenco TT’s? This is a Jean Nantais plinth table ready for a new arm. I don’t want to cut the TT deck so I'm looking for the best arm choices to mount to the Lenco as seen in the picture.
Thanks in advance for any replies:thmbsp:
ED
Have you posted this question on the Lenco Lovers' board, as well as here? While some people are on both boards (here and there), not all are. There is a lot on tonearms there, and you'll get lots of helpful support from some extremely steeped-in-Lenco people there, if you ask nicely!
Hi Ed,
The two "go to" choices for rearming the L75 in the original arm hole are any of the Linn tonearms and the Mayware unipivot.
If you want make an under-the-topplate arm board, any tonearm with a mounting distance of 210mm to 212mm can be made to work fine.
All best,
Mario
Hi Mario,
Thanks for the info. I've ruled out the Linn. I will look at a Mayware.
Audioquest pt-9 seems to be a highly recommended arm on the Lenco Lovers site
ED
