Modifying a RG 1
Rybeam
I have had a RG 1 dynamic expander since they were new and like using it for vinyl and tapes. The one thing I wish I could do is adjust the effect on the high end. I always like the effect it has on the bass, but in many cases I could live with less to none of the effect on the high end.
Can this be done reasonably, or is it way too much. I am not a tech. so I am clueless as to the practical aspects of this idea.
The RG-1 is basically just an active broadband amplifier. It's designed to amplifiy all frequencies equally from my recollection. So if the signal is the punch from a kick drum or that of a crashing cymbal the effect is the same. I think a better answer to your question would be to use an equalizer to adjust the highend. You might be satisfied by adjusting the tone controls on your amp/preamp.
